[mapserver-users] KML as Outputformat returns incorrect coordinates
luis peinado luis.peinado at geodata.es
Wed Jul 6 07:17:58 EDT 2011
Hi all,
I'm having some related problem:
I have no problem with my mapserver png outputformat:
This png request works really fine:
http://geoserver3/wms60/ddgi/servidor/espaisprotegits?FORMAT=image/png&TRANSPARENT=true&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=zonhum&SRS=EPSG%3A4326&BBOX=-1.0469740101326659,41.39036252208658,5.764549426147167,42.77237478582793&WIDTH=1860&HEIGHT=1039
Changing only the FORMAT parameter to KML:
http://geoserver3/wms60/ddgi/servidor/espaisprotegits?FORMAT=KML&TRANSPARENT=true&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=zonhum&SRS=EPSG%3A4326&BBOX=-1.0469740101326659,41.39036252208658,5.764549426147167,42.77237478582793&WIDTH=1860&HEIGHT=1039
(sorry, my server is not at the Internet).
I get as a response an xml file with no extension and taking a look at it
with my text editor, I can see things like
<Polygon><outerBoundaryIs><LinearRing><coordinates>
583.23708456,950.02673133
583.22503040,950.03227145
And these coordinates are wrong.
Mapserver's log doese not seem to show any problem:
Log after the FORMAT=kml query
[Wed Jul  6 13:08:21 2011].550681 CGI Request 1 on process 1073
[Wed Jul  6 13:08:21 2011].550929 msWMSLoadGetMapParams(): enabling
non-square pixels.
[Wed Jul  6 13:08:21 2011].551361 msDrawMap(): kicking into non-square pixel
preserving mode.
[Wed Jul  6 13:08:21 2011].551380 msDrawMap(): rendering using outputformat
named kml (KML).
[Wed Jul  6 13:08:21 2011].551400 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Wed Jul  6 13:08:22 2011].533734 msDrawMap(): Layer 0 (zonhum), 0.982s
[Wed Jul  6 13:08:22 2011].533776 msDrawMap(): Drawing Label Cache, 0.000s
[Wed Jul  6 13:08:22 2011].533791 msDrawMap() total time: 0.983s
[Wed Jul  6 13:08:22 2011].942736 msSaveImage(stdout) total time: 0.409s
[Wed Jul  6 13:08:22 2011].943681 mapserv request processing time (msLoadMap
not incl.): 1.393s
[Wed Jul  6 13:08:22 2011].943700 msFreeMap(): freeing map at 0x9603678.
Can someone help me?
Thanks in advance for any response.
Lluís.
2011/6/6 Joe Franklin <traderboy at yahoo.com>
> I'm using Mapserver 6.0.  I get the same results using the windows MS4W
> version as well as compiling it myself on Centos 5.  I'm including a simple
> map file with an embedded point, but I also tested using a point shapefile.
> Anyone else see this problem?
> Works using shp2img- returns -77.00000000,48.000000000:
> shp2img -m airport.map
> Doesn't work using mapserv CGI or PHP Mapscript - returns
> 76.80000000,409.60000000
> mapserv -nh
> "QUERY_STRING=map=airport.map&service=wms&VERSION=1.1.1&REQUEST=GetMap&SRS=epsg:4326&WIDTH=512&HEIGHT=512&LAYERS=Airports&TRANSPARENT=TRUE&FORMAT=kml&BBOX=-80,40,-60,50"
> MAP
> NAME "Airport"
> STATUS ON
> SIZE 512 512
> EXTENT -80 40 -60 50
> IMAGETYPE kml
> UNITS DD
> IMAGECOLOR 255 255 255
> PROJECTION
>       "init=epsg:4326"
> END
> WEB
>   METADATA
>       "ows_enable_request" "*"
>       "wms_title"           "Airport"
>       "wms_onlineresource"  "http://localhost/mapserv?map=/tmp/airport.map
>       "ows_srs"             "epsg:4326"
>   END
> END  #WEB
> SYMBOL
>         NAME 'circle'
>         TYPE ellipse
>         FILLED true
>         POINTS 1 1 END
> END
> LAYER
>     NAME "Airports"
>     TYPE point
>     FEATURE
>       POINTS -77 48 END
>     END
>     METADATA
>       "wms_title" "Airports"
>     END # METADATA
>     STATUS ON
>     CLASS
>       STYLE
>         COLOR 255 0 0
>         SYMBOL 1
>         SIZE 5
>       END # STYLE
>       TEMPLATE "ttt_query.html"
>     END # CLASS
> END # LAYER
> END
> MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110706/0eeceb30/attachment-0001.html
