[mapserver-users] KML as Outputformat returns incorrect
coordinates
Joe Franklin
traderboy at yahoo.com
Wed Jul 6 11:55:39 EDT 2011
I had to adjust the height parameter to make it work when downloading as KML:
height = ((maxy-miny)/(maxx-minx))*width
It still seems like a bug, but does this help? I guess the WIDTH and HEIGHT parameters don't make much sense when outputting as KML.
----- Original Message -----
From: Jeff McKenna <jmckenna at gatewaygeomatics.com>
To: mapserver-users <mapserver-users at lists.osgeo.org>
Cc:
Sent: Wednesday, July 6, 2011 8:00 AM
Subject: Re: [mapserver-users] KML as Outputformat returns incorrect coordinates
You might be hitting the same issue that I reported a few weeks ago
(http://trac.osgeo.org/mapserver/ticket/3928).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-07-06 8:17 AM, luis peinado wrote:
> Hi all,
> I'm having some related problem:
> I have no problem with my mapserver png outputformat:
> This png request works really fine:
> http://geoserver3/wms60/ddgi/servidor/espaisprotegits?FORMAT=image/png&TRANSPARENT=true&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=zonhum&SRS=EPSG%3A4326&BBOX=-1.0469740101326659,41.39036252208658,5.764549426147167,42.77237478582793&WIDTH=1860&HEIGHT=1039
> <http://geoserver3/wms60/ddgi/servidor/espaisprotegits?FORMAT=image/png&TRANSPARENT=true&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=zonhum&SRS=EPSG%3A4326&BBOX=-1.0469740101326659,41.39036252208658,5.764549426147167,42.77237478582793&WIDTH=1860&HEIGHT=1039>
> Changing only the FORMAT parameter to KML:
> http://geoserver3/wms60/ddgi/servidor/espaisprotegits?FORMAT=KML&TRANSPARENT=true&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=zonhum&SRS=EPSG%3A4326&BBOX=-1.0469740101326659,41.39036252208658,5.764549426147167,42.77237478582793&WIDTH=1860&HEIGHT=1039
> <http://geoserver3/wms60/ddgi/servidor/espaisprotegits?FORMAT=KML&TRANSPARENT=true&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=zonhum&SRS=EPSG%3A4326&BBOX=-1.0469740101326659,41.39036252208658,5.764549426147167,42.77237478582793&WIDTH=1860&HEIGHT=1039>
> (sorry, my server is not at the Internet).
> I get as a response an xml file with no extension and taking a look at
> it with my text editor, I can see things like
> <Polygon><outerBoundaryIs><LinearRing><coordinates>
> 583.23708456,950.02673133
> 583.22503040,950.03227145
> And these coordinates are wrong.
> Mapserver's log doese not seem to show any problem:
> Log after the FORMAT=kml query
> [Wed Jul 6 13:08:21 2011].550681 CGI Request 1 on process 1073
> [Wed Jul 6 13:08:21 2011].550929 msWMSLoadGetMapParams(): enabling
> non-square pixels.
> [Wed Jul 6 13:08:21 2011].551361 msDrawMap(): kicking into non-square
> pixel preserving mode.
> [Wed Jul 6 13:08:21 2011].551380 msDrawMap(): rendering using
> outputformat named kml (KML).
> [Wed Jul 6 13:08:21 2011].551400 msDrawMap(): WMS/WFS set-up and query,
> 0.000s
> [Wed Jul 6 13:08:22 2011].533734 msDrawMap(): Layer 0 (zonhum), 0.982s
> [Wed Jul 6 13:08:22 2011].533776 msDrawMap(): Drawing Label Cache, 0.000s
> [Wed Jul 6 13:08:22 2011].533791 msDrawMap() total time: 0.983s
> [Wed Jul 6 13:08:22 2011].942736 msSaveImage(stdout) total time: 0.409s
> [Wed Jul 6 13:08:22 2011].943681 mapserv request processing time
> (msLoadMap not incl.): 1.393s
> [Wed Jul 6 13:08:22 2011].943700 msFreeMap(): freeing map at 0x9603678.
> Can someone help me?
> Thanks in advance for any response.
> Lluís.
> 2011/6/6 Joe Franklin <traderboy at yahoo.com <mailto:traderboy at yahoo.com>>
> I'm using Mapserver 6.0. I get the same results using the windows
> MS4W version as well as compiling it myself on Centos 5. I'm
> including a simple map file with an embedded point, but I also
> tested using a point shapefile. Anyone else see this problem?
> Works using shp2img- returns -77.00000000,48.000000000:
> shp2img -m airport.map
> Doesn't work using mapserv CGI or PHP Mapscript - returns
> 76.80000000,409.60000000
> mapserv -nh
> "QUERY_STRING=map=airport.map&service=wms&VERSION=1.1.1&REQUEST=GetMap&SRS=epsg:4326&WIDTH=512&HEIGHT=512&LAYERS=Airports&TRANSPARENT=TRUE&FORMAT=kml&BBOX=-80,40,-60,50"
> MAP
> NAME "Airport"
> STATUS ON
> SIZE 512 512
> EXTENT -80 40 -60 50
> IMAGETYPE kml
> UNITS DD
> IMAGECOLOR 255 255 255
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "ows_enable_request" "*"
> "wms_title" "Airport"
> "wms_onlineresource" "http://localhost/mapserv?map=/tmp/airport.map"
> "ows_srs" "epsg:4326"
> END
> END #WEB
> SYMBOL
> NAME 'circle'
> TYPE ellipse
> FILLED true
> POINTS 1 1 END
> END
> LAYER
> NAME "Airports"
> TYPE point
> FEATURE
> POINTS -77 48 END
> END
> METADATA
> "wms_title" "Airports"
> END # METADATA
> STATUS ON
> CLASS
> STYLE
> COLOR 255 0 0
> SYMBOL 1
> SIZE 5
> END # STYLE
> TEMPLATE "ttt_query.html"
> END # CLASS
> END # LAYER
> END
> MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
