[mapserver-users] merging shapefiles
Julien Cigar
jcigar at ulb.ac.be
Thu Jul 7 05:44:29 EDT 2011
Hello,
I have an (OpenLayers) map with two layers:
- Country (as a base layer)
- EEA
You can see the output here:
http://home.bebif.be/~jcigar/map.jpg
The "Country" layer contains just the borders of the countries, and the
"EEA" layer (the colorized areas) contains environmental areas.
What I'd like to do is to select a polygon within a country for a
specific zone. For example I would like to "select part of Belgium with
the Atlantic EEA (in blue)", which is the north of Belgium. I also need
to save some information in the database for the polygon (I'm using
Mapserver/PostGIS).
What would be the best way to do this? Would you "merge" the two layers
into one (be creating new polygons)?
thanks,
Julien
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110707/cb455ee6/jcigar.vcf
