[mapserver-users] merging shapefiles
Edward Mac Gillavry
emacgillavry at hotmail.com
Thu Jul 7 06:01:57 EDT 2011
You may want to investigate the ST_Intersection functionality in PostGIS. This allows you to create a new geometry from the intersection of the EEA regions and the countries.
http://postgis.refractions.net/docs/ST_Intersection.html
Regards,
Edward
Date: Thu, 7 Jul 2011 11:44:29 +0200
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] merging shapefiles
Hello,
I have an (OpenLayers) map with two layers:
- Country (as a base layer)
- EEA
You can see the output here:
http://home.bebif.be/~jcigar/map.jpg
The "Country" layer contains just the borders of the countries, and the
"EEA" layer (the colorized areas) contains environmental areas.
What I'd like to do is to select a polygon within a country for a
specific zone. For example I would like to "select part of Belgium with
the Atlantic EEA (in blue)", which is the north of Belgium. I also need
to save some information in the database for the polygon (I'm using
Mapserver/PostGIS).
What would be the best way to do this? Would you "merge" the two layers
into one (be creating new polygons)?
thanks,
Julien
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110707/5a70395b/attachment-0001.html
