[mapserver-users] Re: Font rendering in MapServer 6.0
thomas bonfort thomas.bonfort at gmail.com
Thu Jul 7 14:37:30 EDT 2011
We've kept the GD renderer in 6.0 for some marginal use cases, but the
preferred way is to switch to AGG rendering (which is compiled in by
default): you can use the builtin png8 imagetype (mimetype: image/png;
mode=8bit) which does a quantization step if you need a 256 color
paletted image.
The easy solution is to remove all your outputformat blocks from your
mapfile, and call your server with FORMAT=image/png or image/png;
mode=8bit , and setting your map imagetype to png or png8.
As for this GD rendering bug, the easy first step is be to open a
bug-report. The harder second step is to get someone motivated to look
into it if you cannot provide a patch.
regards,
thomas
On Thu, Jul 7, 2011 at 20:07, Brad Posthumus <posthumusb at agr.gc.ca> wrote:
> I've narrowed it down further to the OUTPUTFORMAT section of the mapfile,
> which currently is:
>  OUTPUTFORMAT
>    NAME png
>    DRIVER "GD/PNG"
>    MIMETYPE "image/png"
>    IMAGEMODE PC256
>    FORMATOPTION "INTERLACE=OFF"
>    EXTENSION png
>    TRANSPARENT ON
>  END
> It appears to be a problem with having a combination of GD/PNG, PC256, and
> transparency. Turning transparency off renders a clean image, changing PC256
> to RGBA renders a clean image, changing PNG to GIF (at all locations)
> renders a clean image....
> This setup was working in 5.4 and 5.6 so I'll assume it's a bug I should
> report for 6.0.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Font-rendering-in-MapServer-6-0-tp6555935p6559374.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
