[mapserver-users] Maps are not generating
Michael Shishcu micklesh at gmail.com
Sun Jul 10 04:06:57 EDT 2011
Hi Dushi,
in the mapfile the layer has *NAME "cmb_roads_rda",* but you call it from
cgi like layer=states.
You should rename your layer to "states" or change the layers parameter in
url
regards,
michael
On Sun, Jul 10, 2011 at 7:57 AM, Dushi <dushan888 at gmail.com> wrote:
> Hi, I'm a newbee for GIS. I have a posgis database on my working
> environment(template_postgis). i need to retrieve "the_geom" column from  a
> table named "cmb_roads_rda". following is my map file (test.map).
> *MAP
>   IMAGETYPE      PNG
>   EXTENT         -97.238976 41.619778 -82.122902 49.385620
>   SIZE           900 900
>   IMAGECOLOR     255 255 143
>   LAYER
>     NAME         cmb_roads_rda
>     CONNECTIONTYPE postgis
>     CONNECTION "user=postgres password=817888 port=5432
> dbname=template_postgis host=localhost"
>     DATA         "the_geom from cmb_roads_rda"
>     STATUS       ON
>     DEBUG         ON
>     TYPE         LINE
>     CLASS
>       STYLE
>         COLOR        232 232 266
>         OUTLINECOLOR 32 32 33
>       END
>     END
> END
> END
> *I call this map file by calling the following link -->
> http://localhost/cgi-bin/mapserv?map=/var/www/db/test.map&layer=states&mode=map
> but it *only generates a yellow color layer on *the browser and not
> displaying "the_geom" data.
> I'm using mapserver 5.6.6 with apashe2 webserver on linux mint.
> Please be kind to help on this issue. Thank you so much.
> Me on Web
> http://dushan888.wordpress.com
> http://www.twitter.com/Dushi
> http://identi.ca/dushi
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110710/06a24802/attachment.html
