[mapserver-users] msShapefileOpen(): Unable to access file
Dave Chetan
csdave4u at gmail.com
Tue Jul 12 07:58:42 EDT 2011
Hi Rahkonen,
Thanks for the prompt reply..!!
If I add
CONNECTIONTYPE OGR
in the Layer Tag, then the error is
7/12/2011 4:29:20 PM|msDrawMap(): Image handling error. Failed to draw
layer named 'DGN'.;msOGRFileOpen(): OGR error. Open failed for OGR
connection in layer `DGN'. File not found or unsupported format.
7/12/2011 4:29:20 PM| at OSGeo.MapServer.mapObj.draw()
at MapCreator.Controls.MapControl.RefreshMap()
Regards,
Dave C.
On 7/12/11, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I guess that Mapserver is seaching for shapefiles as default. Read the
> document http://mapserver.org/input/vector/ogr.html and have a try with
> CONNECTIONTYPE=OGR.
> -Jukka Rahkonen
> ________________________________________
> Dave Chetan wrote:
> Hi,
> I am publishing DGN data using tile option. I am getting error
> "msShapefileOpen(): Unable to access file".
> Following are the details of Input data, steps executed and error log.
> Please, if anyone can help in resolving the issue.
> Source files are DGN
> D:\Tile\DGN\Final\1.dgn
> D:\Tile\DGN\Final\3.dgn
> D:\Tile\DGN\Final\5.dgn
> D:\Tile\DGN\Final\7.dgn
> D:\Tile\DGN\Final\9.dgn
> Step1)-
> Creation of Index tile
> ogrtindex.exe d:\Tile\DGN\Final\index_dgn.shp d:\Tile\DGN\Final\*.dgn
> Ogrtindex created "index_dgn.shp" index file
> Step2)-
> Map file
> EXTENT 699218.75297987 2251967.57943806 755021.241547886 2291053.54827586
> SHAPEPATH "D:\Tile\DGN\Final"
> LAYER
> NAME "DGN"
> STATUS ON
> TILEINDEX "index_dgn"
> TILEITEM "location"
> TYPE LINE
> UNITS METERS
> CLASS
> NAME "DGN"
> STYLE
> ANGLE 360
> COLOR 240 215 209
> SYMBOL "LineDash"
> WIDTH 1
> END
> END
> END
> Error
> 7/12/2011 4:21:33 PM|msDrawMap(): Image handling error. Failed to draw
> layer named 'DGN'.;msTiledSHPOpenFile(): Shapefile error. Unable to
> open a single tile to use as a template in layer
> DGN.;msShapefileOpen(): Unable to access file.
> (d:\Tile\DGN\Final\9.dgn,0);msShapefileOpen(): Unable to access file.
> (d:\Tile\DGN\Final\7.dgn,0);msShapefileOpen(): Unable to access file.
> (d:\Tile\DGN\Final\5.dgn,0);msShapefileOpen(): Unable to access file.
> (d:\Tile\DGN\Final\3.dgn,0);msShapefileOpen(): Unable to access file.
> (d:\Tile\DGN\Final\1.dgn,0);msShapefileOpen(): Unable to access file.
> 7/12/2011 4:21:33 PM| at OSGeo.MapServer.mapObj.draw()
> In the Layer Tag if I add following line
> CONNECTIONTYPE OGR
> the error is
> mapserver-users at lists.osgeo.org
