[mapserver-users] msShapefileOpen(): Unable to access file
Dave Chetan
csdave4u at gmail.com
Tue Jul 12 08:25:32 EDT 2011
Dear Jukka,
Yes, I am able to publish single DGN.
But when I go for tiled dgn, I have error.
Regards,
Dave C.
On 7/12/11, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I have never played with DGN files with Mapserver. I would blindly follow
> the documents and try first with just one DGN file as in
> http://mapserver.org/input/vector/dgn.html
> and forward next to ogrtileindex as in
> http://mapserver.org/input/vector/ogr.html
> Perhaps there is something important in the syntax of TILEINDEX given in the
> following example.
> LAYER
> NAME "ogr_points"
> TYPE POINT
> CONNECTIONTYPE OGR
> TILEINDEX "PIP_ogr_tiles.shp,0"
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: Dave Chetan [csdave4u at gmail.com]
> Lähetetty: 12. heinäkuuta 2011 14:58
> Vastaanottaja: Rahkonen Jukka
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] msShapefileOpen(): Unable to access file
> Hi Rahkonen,
> Thanks for the prompt reply..!!
> If I add
> CONNECTIONTYPE OGR
> in the Layer Tag, then the error is
> 7/12/2011 4:29:20 PM|msDrawMap(): Image handling error. Failed to draw
> layer named 'DGN'.;msOGRFileOpen(): OGR error. Open failed for OGR
> connection in layer `DGN'. File not found or unsupported format.
> 7/12/2011 4:29:20 PM| at OSGeo.MapServer.mapObj.draw()
> at MapCreator.Controls.MapControl.RefreshMap()
> Regards,
> Dave C.
>> Hi,
>> I guess that Mapserver is seaching for shapefiles as default. Read the
>> document http://mapserver.org/input/vector/ogr.html and have a try with
>> CONNECTIONTYPE=OGR.
>> -Jukka Rahkonen
>> Dave Chetan wrote:
>> Hi,
>> I am publishing DGN data using tile option. I am getting error
>> "msShapefileOpen(): Unable to access file".
>> Following are the details of Input data, steps executed and error log.
>> Please, if anyone can help in resolving the issue.
>> Source files are DGN
>> D:\Tile\DGN\Final\1.dgn
>> D:\Tile\DGN\Final\3.dgn
>> D:\Tile\DGN\Final\5.dgn
>> D:\Tile\DGN\Final\7.dgn
>> D:\Tile\DGN\Final\9.dgn
>> Step1)-
>> Creation of Index tile
>> ogrtindex.exe d:\Tile\DGN\Final\index_dgn.shp d:\Tile\DGN\Final\*.dgn
>> Ogrtindex created "index_dgn.shp" index file
>> Step2)-
>> Map file
>> EXTENT 699218.75297987 2251967.57943806 755021.241547886
>> 2291053.54827586
>> SHAPEPATH "D:\Tile\DGN\Final"
>> LAYER
>> NAME "DGN"
>> STATUS ON
>> TILEINDEX "index_dgn"
>> TILEITEM "location"
>> TYPE LINE
>> UNITS METERS
>> CLASS
>> NAME "DGN"
>> STYLE
>> ANGLE 360
>> COLOR 240 215 209
>> SYMBOL "LineDash"
>> WIDTH 1
>> END
>> END
>> END
>> Error
>> 7/12/2011 4:21:33 PM|msDrawMap(): Image handling error. Failed to draw
>> layer named 'DGN'.;msTiledSHPOpenFile(): Shapefile error. Unable to
>> open a single tile to use as a template in layer
>> DGN.;msShapefileOpen(): Unable to access file.
>> (d:\Tile\DGN\Final\9.dgn,0);msShapefileOpen(): Unable to access file.
>> (d:\Tile\DGN\Final\7.dgn,0);msShapefileOpen(): Unable to access file.
>> (d:\Tile\DGN\Final\5.dgn,0);msShapefileOpen(): Unable to access file.
>> (d:\Tile\DGN\Final\3.dgn,0);msShapefileOpen(): Unable to access file.
>> (d:\Tile\DGN\Final\1.dgn,0);msShapefileOpen(): Unable to access file.
>> 7/12/2011 4:21:33 PM| at OSGeo.MapServer.mapObj.draw()
>> In the Layer Tag if I add following line
>> CONNECTIONTYPE OGR
>> the error is
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
