[mapserver-users] Using unique
Pena Kupen kupen at wippies.fi
Thu Jul 14 03:51:09 EDT 2011
Hello all,
I'm just upgrading our system from mapserver 5.4.2 to 5.6.6.
In some of our layer queries, I got now error:
msPostGISParseData(http://mapserver.org/input/vector/postgis.html): Query error. Error parsing PostGIS DATA variable.  You must specifiy 'using unique' when supplying a subselect in the data definition.
When using 5.4.2, this is not happaning and maps are working ok.
On mapserver/postgis manual ()it says:
The DATA parameter is used to specify the data used to draw the map. The form of DATA is “[geometry_column] from [table_name|sql_subquery] using unique [unique_key] using srid=[spatial_reference_id]”. The “using unique” and “using srid=” clauses are optional, but using them improves performance.
Is this a bug or why I cannot anymore use queries without "using unique"?
-Pena
Wippies-vallankumous on täällä! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
http://www.wippies.com/
