[mapserver-users] Difference in test map behavior from MapServer 5.6.5 to 6.0.1
Havard Tveite havard.tveite at umb.no
Thu Jul 14 18:57:02 EDT 2011
On 14/07/11 22:35, Nicolas Chenier wrote:
> Good day all,
> This is a bump as I never received an answer... Quick update - I updated
> my binary to 6.0.1 but this issue remains:
> I am investigating an issue where the background in the PNG generated by
> the example map that comes with MapServer changes from a red-orange
> color (with MapServer 5.x) to purple (with MapServer 6.x). The font also
> changes. (See attached)
OUTLINECOLOR seems to be interpreted differently in the two
versions.
In 6.0, OUTLINECOLOR is used for the fill symbol (you can
see that the polygon outline is missing, but there is a
lot of blue in the fill).  This behaviour is described in
the 6.0 documentation.
In 5.6, OUTLINECOLOR seems to be used for the polygon outline.
The change may have something to do with the rendering
overhaul and/or AGG / GD differences.
To get a blue polygon outline in 6.0, you could change from:
       STYLE
         COLOR 255 153 102
         OUTLINECOLOR 0 0 204
         SYMBOL 1
         SIZE 2
       END
to:
       STYLE
         COLOR 255 153 102
         SYMBOL 1
         SIZE 2
       END
       STYLE
         WIDTH 1
       END
The font looks similar, except for the scalebar.
Håvard
> The data, symbols, fonts and map files are not touched, the only thing
> that changes is the cgi-bin 'mapserv' binary between MS5 (5.6.5) and MS6
> (6.0.0).
> Any help would be greatly appreciated!
> Thank you,
> Nic
>> test.map (the tests that come with MapServer documentation):
>> MAP
>>    NAME "Testing"
>>    EXTENT -0.5 50.977222 0.5 51.977222
>>    #IMAGETYPE JPEG
>>    #IMAGETYPE PNG24
>>    IMAGETYPE PNG
>>    IMAGECOLOR 255 255 255
>>    STATUS ON
>>    SIZE 200 200
>>    FONTSET "fonts.txt"
>>    SYMBOLSET "symbols.txt"
>>    SCALEBAR
>>      STATUS EMBED
>>      POSTLABELCACHE TRUE
>>      STYLE 0
>>      UNITS METERS
>>      SIZE 150 3
>>      POSITION LR
>>      TRANSPARENT TRUE
>>      COLOR 0 0 0
>>      IMAGECOLOR 242 255 195
>>      BACKGROUNDCOLOR 255 255 255
>>      LABEL
>>        TYPE BITMAP
>>        SIZE TINY
>>        COLOR 0 0 0
>>        POSITION UR
>>        BUFFER 10
>>      END
>>    END
>>    LEGEND
>>    END
>>    WEB
>>      METADATA
>>        "key1" "value1"
>>        "key2" "value2"
>>        "key3" "value3"
>>        "key4" "value4"
>>      END
>>    END
>>    PROJECTION
>>      "init=epsg:4326"
>>    END
>>    LAYER
>>      NAME "RASTER"
>>      TYPE RASTER
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      DATA "raster.tif"
>>      PROCESSING "BANDS=1"
>>      STATUS DEFAULT
>>    END
>>    LAYER
>>      NAME "POLYGON"
>>      TYPE POLYGON
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      STATUS DEFAULT
>>      DATA "polygon"
>>      METADATA
>>        "key1" "value1"
>>        "key2" "value2"
>>        "key3" "value3"
>>        "key4" "value4"
>>      END
>>      CLASSITEM "FNAME"
>>      CLASS
>>        NAME "0"
>>        METADATA
>>          "key1" "value1"
>>          "key2" "value2"
>>          "key3" "value3"
>>          "key4" "value4"
>>        END
>>        STYLE
>>          COLOR 255 153 102
>>          SYMBOL 1
>>          SIZE 2
>>        END
>>      END
>>      CLASS
>>        NAME "1"
>>        EXPRESSION "foo"
>>        STYLE
>>          COLOR 255 153 102
>>          SYMBOL 1
>>          SIZE 2
>>        END
>>      END
>>    END
>>    LAYER
>>      NAME "LINE"
>>      TYPE LINE
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      TRANSPARENCY 1
>>      STATUS DEFAULT
>>      DATA "line"
>>      CLASSITEM "FNAME"
>>      CLASS
>>        NAME "0"
>>        STYLE
>>          COLOR 0 153 0
>>          SYMBOL 1
>>          SIZE 3
>>        END
>>      END
>>      CLASS
>>        NAME "1"
>>        EXPRESSION "foo"
>>        STYLE
>>          COLOR 0 153 0
>>          SYMBOL 1
>>          SIZE 3
>>        END
>>      END
>>    END
>>    LAYER
>>      NAME "POINT"
>>      EXTENT -0.5 51.0 0.5 52.0
>>      TYPE POINT
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      STATUS DEFAULT
>>      DATA "point"
>>      CLASSITEM "FNAME"
>>      LABELITEM "FNAME"
>>      CLASS
>>        NAME "0"
>>        STYLE
>>          COLOR 0 0 0
>>          SYMBOL 1
>>          SIZE 13
>>        END
>>        STYLE
>>          COLOR 204 204 204
>>          SYMBOL 1
>>          SIZE 7
>>        END
>>        LABEL
>>          TYPE TRUETYPE
>>          FONT "Vera"
>>          SIZE 10
>>          COLOR 0 0 0
>>        END
>>        TEMPLATE "point.html"
>>      END
>>      CLASS
>>        NAME "1"
>>        EXPRESSION "foo"
>>        STYLE
>>          COLOR 0 0 0
>>          SYMBOL 1
>>          SIZE 13
>>        END
>>      END
>>    END
>>    LAYER
>>      NAME "INLINE"
>>      TYPE POINT
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      STATUS DEFAULT
>>      FEATURE
>>        POINTS -0.2 51.5 END
>>      END
>>      CLASS
>>        NAME "0"
>>        STYLE
>>          COLOR 0 0 0
>>          SYMBOL 1
>>          SIZE 3
>>        END
>>      END
>>    END
>>    LAYER
>>      NAME "INLINE-PIXMAP-RGBA"
>>      TYPE POINT
>>      TRANSPARENCY ALPHA
>>      DEBUG ON
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      STATUS OFF
>>      FEATURE
>>        POINTS 0.2 51.7 END
>>      END
>>      CLASS
>>        NAME "0"
>>        STYLE
>>          SYMBOL 'xmarks-png'
>>        END
>>        LABEL
>>          COLOR 0 0 0
>>        END
>>      END
>>    END
>> LAYER
>>      NAME "INLINE-PIXMAP-PCT"
>>      TYPE ANNOTATION
>>      DEBUG ON
>>      TRANSPARENCY ALPHA
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      STATUS DEFAULT
>>      FEATURE
>>        POINTS 0.2 51.2 END
>>      END
>>      CLASS
>>        NAME "0"
>>        STYLE
>>          SYMBOL 'home-png'
>>        END
>>        TEXT "."
>>        LABEL
>>          COLOR 0 0 0
>>        END
>>      END
>>    END
>> END
>> symbols.txt:
>> SYMBOLSET
>>      SYMBOL
>>          NAME 'circle'
>>          TYPE ellipse
>>          FILLED true
>>          POINTS
>>            1 1
>>          END
>>      END
>>      SYMBOL
>>          NAME 'xmarks-png'
>>          TYPE PIXMAP
>>          IMAGE 'xmarks.png'
>>      END
>>      SYMBOL
>>          NAME 'home-png'
>>          TYPE PIXMAP
>>          IMAGE 'home.png'
>>      END
>> END
