[mapserver-users] Using unique
Pena Kupen
kupen at wippies.fi
Fri Jul 15 03:05:42 EDT 2011
Hi again,
I'm answering to my by myself :-)
When I add to the end of my query "using unique" as:
" as foobar using unique oid "
then query is again running ok.
I also tried it with older version of Mapserver (5.4.2). Both versions are working ok with it.
After some debugging of version 5.6.6, it seems to me , that in query, there is missing last right parenthesis if "using unique" is omitted. Some bug?
-Pena
Pena Kupen [kupen at wippies.fi] kirjoitti:
> Hello Carlos and all,
> I'm using query, which is little cryptic.
> location from (
> select h.location, h.oid, k.expla, h.date1, h.expla, h.total, ku.locationname as name
> from
> (select pa.location, ha.type_id as oid, ha.date1, pa_n.name, pa_n.location_id, ha.car_id, ha.total
> from pa
> join ha on ha.ha_pa_id = pa.pa_id
> left join pa_n on pa.pa_id = pa_n.pa_id
> where
> ha.type_id = 121557 and
> status='11' and
> ha.is_valid is NULL
> ) as h
> left join ku on h.ku_id=ku.ku_id
> left join k on h.type_id = k.type_id
> where
> k.code='sc' and
> syno=false and
> (h.ku_id = 'AAC')
> ) as foobar
> This has been used without any problem.
> -Pena
> Carlos Ruiz [boolean10001 at yahoo.com] kirjoitti:
> > Pena,
> > Can you post your query ?
> > You can use:
> > DATA "the_geom FROM <table>"in the traditional way
> > Or, if you're using a query or a view datasource, you can use:
> > DATA "the_geom FROM <query>|<view> AS <alias> USING UNIQUE <column> USING SRID=<SRC>
> > Cheers from México
> > IC Carlos Ruiz
> > ________________________________
> > From: Pena Kupen <kupen at wippies.fi>
> > To: mapserver-users at lists.osgeo.org
> > Sent: Thursday, July 14, 2011 2:59 AM
> > Subject: [mapserver-users] Using unique
> > Sorry doubleposting! There where little "copy/paste-error". You can ignore prior...
> > -Pena
> > Hello all,
> > I'm just upgrading our system from mapserver 5.4.2 to 5.6.6.
> > In some of our layer queries, I got now error:
> > msPostGISParseData(): Query error. Error parsing PostGIS DATA variable. You must specifiy 'using unique' when supplying a subselect in the data definition.
> > When using 5.4.2, this is not happaning and maps are working ok.
> > On mapserver/postgis manual (http://mapserver.org/input/vector/postgis.html) it says:
> > The DATA parameter is used to specify the data used to draw the map. The form of DATA is
[geometry_column] from [table_name|sql_subquery] using unique [unique_key] using srid=[spatial_reference_id]
. The
using unique
and
using srid=
clauses are optional, but using them improves performance.
> > Is this a bug or why I cannot anymore use queries without "using unique"?
> > -Pena
> > -- Wippies-vallankumous on täällä! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
> > http://www.wippies.com/
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
