[mapserver-users] Mapfile layer not displaying in MapServer 6.0.1
(does in 5.4)
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Fri Jul 15 13:22:28 EDT 2011
I'm having a problem upgrading from MapServer 5.4 to 6.0.1, so thought I'd
start from scratch trying to isolate my ultimate problem. To start, all I am
trying to do is display a simple Mapfile line layer in my browser. I have
(what I believe to be) the simplest Mapfile I can make that allows me to do
a mode=map display in 5.4. But, when I try to use the same Mapfile with the
6.0.1 installation, the layer does not display.
I have reviewed the "MapServer Migration Guide" and the online 6.0
documentation but can't see anything in this simple Mapfile that would cause
the lack of display...although it's probably staring me in the face, I know.
Anyway, I don't believe there's an actual "problem" per se (debugging
results attached below), I assume there's just a difference between how I'm
supposed to define something for 5.4 and how it should be defined for 6.0.
The only thing I can think of that might be affecting this is the
OUTPUTFORMAT changes but I certainly can't see what the problem might be. I
also looked into some of the line styling changes, but don't think any of
them apply to this example. I'm hoping another set of eyes (that have more
experience with these changes than I) can identify what I am defining
incorrectly for 6.0.
Cheers,
jtm
I provide the URL "http://<domain>/ogc/joanne?mode=map&layers=Roads25" and
when I point to the MapServer 5.4's domain I see the roads layer, but if I
point to the MapServer 6.0.1 domain (which is basically the same as the 5.4
environment - essentially a fully complete mirror), the result is an empty
image. No errors, no problem; but no roads either.
The wrapper file contains:
MS_MAPFILE=${MS_APPSPATH}joanne/map/joanne_sub.map
export MS_MAPFILE
${MS_CGIBIN}mapserv
And the Mapfile "joanne_sub.map" contents are below. It's as simple as I
could make it.
MAP
NAME "mySubMap"
FONTSET "../../../mapserv/etc/fonts.txt"
SYMBOLSET "../../../mapserv/etc/symbols.sym"
SIZE 800 600
IMAGETYPE PNG
IMAGECOLOR 255 255 255
EXTENT -2903297.697389 -789911.662978 3431059.382789 3959683.443689
UNITS METERS
PROJECTION
"init=epsg:42304"
END
WEB
IMAGEPATH "/<path>/httpd/htdocs/ogc_tmp/"
IMAGEURL "/ogc_tmp/"
END #end WEB
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END #end OUTPUTFORMAT
LAYER
NAME 'Roads25M'
TYPE LINE
STATUS ON
CONNECTION "<host>,<port>,sde,<username>,<password>"
CONNECTIONTYPE SDE
DATA 'XDM_XDATA.TRN_NSF_ROAD_V6_CT25M_R2,SHAPE,SDE.DEFAULT'
CLASS
STYLE
COLOR 0 0 0
END #end STYLE
END #end CLASS
END #end LAYER
END #end MAP
5.4 debug results for
"http://<5.4Domain>/ogc/joanne?mode=map&layers=Roads25" request:
[Fri Jul 15 12:48:39 2011].722684 msDrawMap(): Layer 0 (Roads25M), 0.742s
[Fri Jul 15 12:48:39 2011].722837 msDrawMap(): Drawing Label Cache, 0.000s
[Fri Jul 15 12:48:39 2011].722846 msDrawMap() total time: 0.742s
[Fri Jul 15 12:48:39 2011].735882 msSaveImage() total time: 0.013s
[Fri Jul 15 12:48:39 2011].735953 mapserv request processing time (loadmap
not incl.): 0.756s
[Fri Jul 15 12:48:39 2011].735960 msFreeMap(): freeing map at 0x8b5f1a0.
6.0.1 debug results for
"http://<6.0.1Domain>/ogc/joanne?mode=map&layers=Roads25" request:
[Fri Jul 15 12:48:41 2011].658817 msDrawMap(): rendering using outputformat
named png (AGG/PNG).
[Fri Jul 15 12:48:41 2011].658911 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Fri Jul 15 12:48:41 2011].658996 msDrawMap(): Drawing Label Cache, 0.000s
[Fri Jul 15 12:48:41 2011].659004 msDrawMap() total time: 0.002s
[Fri Jul 15 12:48:41 2011].743425 msSaveImage(stdout) total time: 0.084s
[Fri Jul 15 12:48:41 2011].743545 mapserv request processing time (loadmap
not incl.): 0.087s
[Fri Jul 15 12:48:41 2011].743557 msFreeMap(): freeing map at 0x8261138.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapfile-layer-not-displaying-in-MapServer-6-0-1-does-in-5-4-tp6587562p6587562.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
