[mapserver-users] Re: Mapfile layer not displaying in MapServer 6.0.1 (does in 5.4)
myOpenLayersUName joanne.mcgraw at SYMPATICO.CA
Fri Jul 15 17:26:18 EDT 2011
I tried making the Mapfile even simpler and removing SDE from the mix. I
created a Shapefile of the layer and now the Mapfile is:
MAP
  NAME "mySubMap"
  FONTSET "../../../mapserv/etc/fonts.txt"
  SYMBOLSET "../../../mapserv/etc/symbols.sym"
  SHAPEPATH "/<path>/httpd/apps/joanne/data"
  SIZE 800 600
  IMAGETYPE PNG
  IMAGECOLOR 255 255 255
  EXTENT -2903297.697389 -789911.662978 3431059.382789 3959683.443689
  UNITS METERS
  PROJECTION
    "init=epsg:42304"
  END
  WEB
    IMAGEPATH "/<path>/httpd/htdocs/ogc_tmp/"
    IMAGEURL "/ogc_tmp/"
  END #end WEB
  OUTPUTFORMAT
    NAME 'AGG'
    DRIVER AGG/PNG
    MIMETYPE "image/png"
    IMAGEMODE RGB
    EXTENSION "png"
  END #end OUTPUTFORMAT
  LAYER
    NAME 'Roads25M'
    TYPE LINE
    STATUS ON
    DATA "roads"
    CLASS
      STYLE
        COLOR 0 0 0
      END #end STYLE
    END #end CLASS
  END #end LAYER
END #end MAP
Still no luck. Works in 5.4; not in 6.0.1.
The only other thing I can think of to try next is to actually compile 5.4
and 6.0.1 on the same host and just call them appropriately in the exact
same environment. I'll try that next, but if someone sees something
glaringly erroneous for a MapServer 6.0 Mapfile I'd appreciate a heads-up.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapfile-layer-not-displaying-in-MapServer-6-0-1-does-in-5-4-tp6587562p6588088.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
