[mapserver-users] defresolution and resolution issues in Mapserver 6
thomas bonfort thomas.bonfort at gmail.com
Mon Jul 18 12:44:45 EDT 2011
Mike,
I am not able to reproduce with the msautotest tests:
These are the steps I have taken, in msautotest/renderers
- mapserv -nh QUERY_STRING='map=point_ellipse.map&mode=map&map_resolution=144&map_size=800+600'
> result/point_ellipse.png.png
- convert -scale 50% result/point_ellipse.png.png result/point_ellipse.png.png
- compare visually expected/point_ellipse.png.png
result/point_ellipse.png.png which should be nearly identical
ps: I've added the labels-anno.map test in case the problem you werre
having only affects annotation layers, but that does not seem to be
the case.
thomas
On Mon, Jul 18, 2011 at 16:49, Smith, Michael ERDC-CRREL-NH
<Michael.Smith at usace.army.mil> wrote:
> All,
> I'm seeing symbol scaling and label size/placement issues (see images and
> pdfs for differences) when trying to scale up for higher resolution output.
> Font size is scaling properly but the symbols are larger at higher dpi than
> it should be and labels are not being displayed (perhaps due to label buffer
> issues) at the higher dpi.
> Are there additional settings I should be making beyond setting resolution
> and defresolution?
> Example URLs
> http://localgost/cgi-bin/mapserv6?TRANSPARENT=true&map_resolution=72&MAP_IMAGETYPE=png&MAPEXT=-8043793.5+5411335.5+-8041721.0+5413610.5&map_defresolution=72&MAP_SIZE=440+483&LAYERS=watersmap&MODE=map&MAP=cm2_test.map
> http://localhost/cgi-bin/mapserv6?TRANSPARENT=true&map_resolution=144&MAP_IMAGETYPE=png&MAPEXT=-8043793.5+5411335.5+-8041721.0+5413610.5&map_defresolution=72&MAP_SIZE=880+966&LAYERS=watersmap&MODE=map&MAP=cm2_test.map
> Mike
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> mapserver-users at lists.osgeo.org
