[mapserver-users] defresolution & resolution in 6.0
thomas bonfort
thomas.bonfort at gmail.com
Mon Jul 18 13:52:09 EDT 2011
Richard,
I was also unable to reproduce your issue (see the similar titled
thread initiated by Mike Smith), using the
msautotest/renderers/polygon-as-line.map
please submit a self-contained test-case where the issue can be reproduced.
thanks,
thomas
On Sun, Jul 17, 2011 at 21:35, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> When I use defresolution & resolution in MapServer 6.0 on lines with a
> width of 1 nothing is displayed. Specifically I am using:
> map.defresolution=96&map.resolution=144
> on a polygon layer defined as:
> CLASS
> NAME "Lot and Parcel Lines"
> STYLE
> OUTLINECOLOR 255 0 0
> WIDTH 1
> END
> END
> Example (works):
> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map
> Example, with defresolution & resolution doesn't work:
> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=96&map.resolution=144
> Any insight would be appreciated.
> Thanks,
> Rich
> Richard Greenwood
> www.greenwoodmap.com
> mapserver-users at lists.osgeo.org
