[mapserver-users] defresolution & resolution in 6.0
thomas bonfort
thomas.bonfort at gmail.com
Tue Jul 19 02:37:04 EDT 2011
On Mon, Jul 18, 2011 at 21:31, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> thomas,
> Thank you for your reply. This link should produce an image with lines rendered:
> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=72&map.resolution=144
> This is the same except with map.resolution=100 and lines are not
> rendered, image is blank:
> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=72&map.resolution=100
> When map.defresolution=72, any value for map.resolution between 73 and
> 143 fails to render lines. Similarly when map.defresolution=10, any
> value for map.resolution between 11 and 19 fails to render lines.
> You can easily change defresolution and resolution in the URL yourself
> to see the behavior.
> If you consider this a bug I am happy to file a ticket, but I'd like
> another set of eyes on it before I do so.
This definitely seems like a bug, go ahead and file a ticket !
thanks,
thomas
> Thank you,
> Rich
> On Mon, Jul 18, 2011 at 11:52 AM, thomas bonfort
> <thomas.bonfort at gmail.com> wrote:
>> Richard,
>> I was also unable to reproduce your issue (see the similar titled
>> thread initiated by Mike Smith), using the
>> msautotest/renderers/polygon-as-line.map
>> please submit a self-contained test-case where the issue can be reproduced.
>> thanks,
>> thomas
>> On Sun, Jul 17, 2011 at 21:35, Richard Greenwood
>>> When I use defresolution & resolution in MapServer 6.0 on lines with a
>>> width of 1 nothing is displayed. Specifically I am using:
>>> map.defresolution=96&map.resolution=144
>>> on a polygon layer defined as:
>>> CLASS
>>> NAME "Lot and Parcel Lines"
>>> STYLE
>>> OUTLINECOLOR 255 0 0
>>> WIDTH 1
>>> END
>>> END
>>> Example (works):
>>> Example, with defresolution & resolution doesn't work:
>>> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=96&map.resolution=144
>>> Any insight would be appreciated.
>>> Thanks,
>>> Rich
>>> Richard Greenwood
>>> www.greenwoodmap.com
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard Greenwood
