[mapserver-users] mapserver publish road
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Jul 19 08:23:50 EDT 2011
I believe that most cartographers would say that the uDig way to to draw the outlines is ugly and the Mapserver way looks better but it is partly a matter of taste.  However, at least for me the continuous black lines also give a feeling that it is not possible or allowed to drive from one street to another.
I would try to draw the streets as two separate layers with own styels instead of a single layer with two styles, perhaps that would lead to continuos black outlines.
-Jukka Rahkonen-
 赫玄惠 [xiaoshitou1986126 at 126.com] wrote:
> I encounter a question. use one  same shape file, when I use it in mapserver it like
[cid:752891ff$1$13140d5bf06$Coremail$xiaoshitou1986126 at 126.com]
but in udig it like
[cid:3a893870$2$13140d5bf06$Coremail$xiaoshitou1986126 at 126.com]
when two street intersect together, udig can paint map with the black border,but mapserver can't. Anyone know why?
my mapfile is this:
MAP
  SIZE 800 450
  EXTENT -200 0 200 100
  IMAGECOLOR 180 180 250
  UNITS DD
  debug 5
  CONFIG "MS_ERRORFILE" "\ms4w\tmp\ms_error.txt"
  FONTSET "D:\ms4w\apps\fonts\fonts.list"
PROJECTION
    "init=epsg:4326"
END
OUTPUTFORMAT
    NAME png24#AGG
    DRIVER "GD/PNG" #AGG/PNG    IMAGEMODE RGB
    MIMETYPE IMAGE/PNG
    EXTENSION PNG
    #FORMATOPTION TRANSPARENT=ON
    #FORMATOPTION INTERLANCE=OFF
END
IMAGETYPE png24 #AGG
WEB
    IMAGEPATH "\ms4w\Apache\htdocs\tmp\"
    IMAGEURL "\tmp\"
END
SYMBOL
  NAME 'cartoline'
  TYPE CARTOLINE
  LINECAP  butt
   LINEJOIN  bevel
   LINEJOINMAXSIZE 3
END
LAYER
    NAME 01
    TYPE LINE
    debug 5
    STATUS on
    TRANSPARENCY alpha
    CONNECTIONTYPE postgis
    CONNECTION "user=* dbname=* host=* port=* password=* "
    DATA "the_geom from *** using unique gid"
    processing "slose_connection=defer"
    DUMP TRUE
    CLASS
      STYLE
           COLOR 0 0 0
           SYMBOL 'cartoline'
           ANTIALIAS TRUE
        SIZE 10
        END
         STYLE
           COLOR 255 255 0
           SYMBOL 'cartoline'
           ANTIALIAS TRUE
 &nbs p;      SIZE 8
        END
    END
END
END
