[mapserver-users] ms4w 2.3.1. and ArcSDE
Brent Fraser
bfraser at geoanalytic.com
Tue Jul 19 10:26:32 EDT 2011
Flavio,
Last year I experimented with MS4W and SDE 9.3
(http://lists.maptools.org/pipermail/ms4w-users/2010-January/001402.html).
I used a couple of Windows tools: Dependency Walker (to see which DLLs a
DLL depends on), and Process Monitor (to see which files, including
DLLs, a process is trying to load at run time).
Best Regards,
Brent Fraser
On 7/19/2011 2:46 AM, Flavio Hendry wrote:
> Hi all
> Anyone successful installing and connecting to ArcSDE (9.0, SQL
> Server) with ms4w 2.3.1? We followed all instructions, however we get
> an internal server error ([error] [client 127.0.0.1] Premature end of
> script headers: php-cgi.exe) when trying to connect (see MapFile
> extract below). One problem could be that in 2.3.1 ms4w was compiled
> using GDAL 1.6 and the GDAL/OGR SDE DLLs with GDAL 1.5 ... However, I
> do not see any dependency problems ...
> - ArcSDE SDK is installed, added to path
> - GDAL/OGR plug-ins are copied to "gdalplugins" dir and load the
> sde90.dll (dependencies), however work with GDAL 1.5
> - msplugin_sde_90.dll loads sde90.dll etc. (dependencies), works with
> GDAL 1.6
> - ogrinfo --formats does not show SDE
> Any hints or ideas? THX!
> LAYER
> NAME "Basemap"
> TYPE POINT
> CONNECTIONTYPE PLUGIN
> CONNECTION "xxx.xxx.xx.x,port:5151,sde,uid,password"
> PLUGIN "C:/ms4w/Apache/specialplugins/msplugin_sde_90.dll"
> DATA "SDE.Test,SHAPE,SDE.DEFAULT"
> CLASS
> STYLE
> SYMBOL 'continue'
> SIZE 1
> COLOR -255 0 0
> END
> END
> PROJECTION
> "init=epsg:23033"
> END
> END
> Mit freundlichem Gruss / Best regards
> Flavio Hendry
> TYDAC Inc. - http://www.tydac.ch
> Web Mapping - http://www.mapserver.ch
> Swiss Maps - http://www.mapplus.ch
> ############ Mit freundlichen Gruessen / Kind Regards
> ############ Flavio Hendry, CEO - mailto:flavio at tydac.ch
> ############ TYDAC AG - http://www.tydac.ch
> #### #### Geographic Information Solutions
> #### #### Optingenstrasse 27 -- CH-3013 Bern
> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
> Location: http://www.mapplus.ch/adr/bern/optingenstrasse/27
> mapserver-users at lists.osgeo.org
