[mapserver-users] Re: ArcSDE 9.3.1 QUERYMAP, QUERY or GETFEATUREINFO not workin (Mapserver 6)
Brent Fraser bfraser at geoanalytic.com
Tue Jul 19 23:40:06 EDT 2011
I don't think png24 is defined by default.  You either need to define an
OUTPUTFORMAT with a NAME of png24, or use a default one
(http://mapserver.org/mapfile/outputformat.html#outputformat) like "png"
Best Regards,
Brent Fraser
On 7/19/2011 4:05 PM, Michelle Douvil wrote:
> Thanks for this information Brent..
> I tried the following ..
> mapserv -nh
> "QUERY_STRING=map=e:/sw_nt/ms4w/mapfiles/3.map&mode=nquery&qformat=png24&&mapxy=1186128
> 863840">  e:\sw_nt\mapserver\testms4w.png
> and the result now is a 0 kilobyte png.. and the log file does not report
> anything ..
> a getFeatureINFO request does not find any features..
> mapserv
> "QUERY_STRING=map=e:/sw_nt/ms4w/mapfiles/3.map&LAYERS=DBM_7H_MIL_POLITICAL_POLY_BC&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/jpeg&SRS=EPSG:3005&BBOX=1136822.19419924,815982.719048714,1186128.62547289,863840.736184577&X=250&Y=250&INFO_FORMAT=text/plain&QUERY_LAYERS=DBM_7H_MIL_POLITICAL_POLY_BC&WIDTH=650&HEIGHT=650&FEATURE_COUNT=30"
> msQueryByPoint(): Search returned no results. No matching record(s) found.
> Content-type: text/plain
> GetFeatureInfo results:
> for same data Mapserver 5.2 returns this..
> E:\sw_nt\mapserver>mapserv
> "QUERY_STRING=map=e:/sw_nt/mapfiles6/base2.map&LAYER
> Layer 'DBM_7H_MIL_POLITICAL_POLY_BC'
>    Feature 97:
>      STATUS = 'Province'
>      NAME = 'British Columbia'
>      ENGLISH_NAME = 'British Columbia'
>      FRENCH_NAME = 'Colombia-Britannique'
>      REGION_CODE = '59'
>      POLYGON_FEATURE = '0'
>      ISLAND = ''
>      ISLAND_ENGLISH_NAME = ''
>      ISLAND_FRENCH_NAME = ''
>      NATION_ENGLISH_NAME = 'Canada'
>      NATION_FRENCH_NAME = 'Canada'
> I could give my full mapfile syntax if interested..
> Perhaps I am missing a config statement that would make this work for SDE..
> Thanks,
> Michelle
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/ArcSDE-9-3-1-QUERYMAP-QUERY-or-GETFEATUREINFO-not-workin-Mapserver-6-tp6600091p6600531.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
