[mapserver-users] Re: ArcSDE 9.3.1 QUERYMAP,
QUERY or GETFEATUREINFO not workin (Mapserver 6)
Michelle Douvil
mrdouville at shaw.ca
Wed Jul 20 18:42:50 EDT 2011
I have set up GDB to trace mapserv.exe (MS4W 3)...and received a Segmentation
fault with the plugin..
Starting program: E:\sw_nt\ms4w\Apache\cgi-bin\mapserv.exe
"QUERY_STRING=map=e:/sw_nt/ms4w/mapfiles/3.map&mode=query&qformat=text/plain&mapxy=1186128
863840"
[New Thread 2148.0x1798]
Program received signal SIGSEGV, Segmentation fault.
0x03c43aab in ?? ()
from E:\sw_nt\ms4w\Apache\specialplugins\msplugin_sde_93.dll
FOR SDE DRIVER MAPSERVER build.. (CONNECTION TYPE is SDE)
Mapserver 5.2 works...
Starting program: E:\sw_nt\mapserver\mapserv.exe
"QUERY_STRING=map=e:/sw_nt/mapf
iles/base2.map&LAYERS=DBM_7H_MIL_POLITICAL_POLY_BC&SERVICE=WMS&VERSION=1.1.1&REQ
UEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/j
peg&SRS=EPSG:3005&BBOX=1136822.19419924,815982.719048714,1186128.62547289,863840
.736184577&X=250&Y=250&INFO_FORMAT=text/plain&QUERY_LAYERS=DBM_7H_MIL_POLITICAL_
POLY_BC&WIDTH=650&HEIGHT=650&FEATURE_COUNT=30"
*[New Thread 2168.0x1a60]
[New Thread 2168.0x218]* *with Two threads...*
Content-type: text/plain
GetFeatureInfo results:
Layer 'DBM_7H_MIL_POLITICAL_POLY_BC'
Feature 97:
STATUS = 'Province'
NAME = 'British Columbia'
ENGLISH_NAME = 'British Columbia'
FRENCH_NAME = 'Colombia-Britannique'
REGION_CODE = '59'
POLYGON_FEATURE = '0'
ISLAND = ''
ISLAND_ENGLISH_NAME = ''
ISLAND_FRENCH_NAME = ''
NATION_ENGLISH_NAME = 'Canada'
NATION_FRENCH_NAME = 'Canada'
GEOMETRY = '<shape>'
OBJECTID = '97'
Program exited normally.
With Mapserver 6.. no features are returned for same layer..
(gdb) target exec E:\sw_nt\mapserver6\mapserv.exe
<_POLITICAL_POLY_BC&WIDTH=650&HEIGHT=650&FEATURE_COUNT=30"
Starting program: E:\sw_nt\mapserver6\mapserv.exe
files6/base2.map&LAYERS=DBM_7H_MIL_POLITICAL_POLY_BC&SERVICE=WMS&VERSION=1.1.1&R
EQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image
/jpeg&SRS=EPSG:3005&BBOX=1136822.19419924,815982.719048714,1186128.62547289,8638
40.736184577&X=250&Y=250&INFO_FORMAT=text/plain&QUERY_LAYERS=DBM_7H_MIL_POLITICA
*[New Thread 6300.0x6b4]* *- with one thread*
Search returned no results.
This is the mapfile declaration for each the layer..for both Mapserver 5.2
and 6.0
LAYER
STATUS DEFAULT
NAME 'DBM_7H_MIL_POLITICAL_POLY_BC'
CONNECTIONTYPE sde
CONNECTION 'server,port:5152,sde,username,password'
DATA 'WHSE_BASEMAPPING.DBM_BC_7H_MIL_POLITICAL_POLY,GEOMETRY'
LABELITEM 'NAME'
CLASSITEM ENGLISH_NAME
CLASS
NAME 'British Columbia'
EXPRESSION ('[ENGLISH_NAME]' eq 'British Columbia')
STYLE
COLOR 255 190 190
OUTLINECOLOR 0 0 0
END #end style
LABEL
COLOR 168 0 0
FONT arial
TYPE truetype
SIZE 8
POSITION cc
PARTIALS FALSE
BUFFER 1
#BACKGROUNDCOLOR 254 254 254
MINDISTANCE 300
END #end label
END #end class
TYPE polygon
LABELMINSCALEDENOM 5000001
MINSCALEDENOM 2000001
# MAXSCALEDENOM 35000000
# STATUS ON
PROJECTION
"init=epsg:3005"
END
METADATA
wms_title "British Columbia"
wms_metadataurl_format "html"
wms_metadataurl_href "http://metadata"
wms_metadataurl_type "TC211"
wfs_title "British Columbia"
gml_geometries "geom"
gml_geom_type "polygon"
wms_include_items "all"
gml_include_items "all"
gml_exclude_items "GEOMETRY,OBJECTID"
END #metadata
PROCESSING "CLOSE_CONNECTION=DEFER"
PROCESSING "LABEL_NO_CLIP=on"
DUMP TRUE # Used to enable GetFeatureInfo
TEMPLATE "foo.html"
OPACITY 20
END #end layer
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ArcSDE-9-3-1-QUERYMAP-QUERY-or-GETFEATUREINFO-not-workin-Mapserver-6-tp6600091p6604735.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
