[mapserver-users] Re: Can't WFS getFeature w/MapServer 6.0.1
myOpenLayersUName joanne.mcgraw at SYMPATICO.CA
Thu Jul 21 10:12:22 EDT 2011
This is a correction and additional information to previous post.
In my first post, I said "However, the SDE log suggests the query took place
and returned successfully." Upon closer inspection, this is not actually the
case.
Watching the SDE logs while trying to perform my query with 5.6.3, I see the
following:
Thu Jul 21 09:01:52 2011 - SDE Server Pid 11962 Registered, User:
<Username> Schema: sde.
Thu Jul 21 09:01:52 2011 - SDE Server 11962 exit'd with status 0
Thu Jul 21 09:01:52 2011 - SDE Server Pid 11962 Stopped, User: <Username>
Schema: sde.
Thu Jul 21 09:01:54 2011 - SDE Server Pid 11963 Registered, User:
Thu Jul 21 09:01:58 2011 - SDE Server 11963 exit'd with status 0
Thu Jul 21 09:01:59 2011 - SDE Server Pid 11963 Stopped, User: <Username>
Schema: sde.
When I perform the same query with 6.0.1, only one connection is made:
Thu Jul 21 09:00:37 2011 - SDE Server Pid 11224 Registered, User:
Thu Jul 21 09:00:37 2011 - SDE Server 11224 exit'd with status 0
Thu Jul 21 09:00:37 2011 - SDE Server Pid 11224 Stopped, User: <Username>
Schema: sde.
So, while that one connection appears to perform successfully, there is no
second connection at all (which according to what happens with 5.6.3, there
should be). Somewhere between the "handshaking" (or whatever the heck it is)
and the actual query being performed, something is going off the rails.
Perhaps the connection value in layer->layerinfo being invalid in some way
is stopping the second connection? It's also unable to free it.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-WFS-getFeature-w-MapServer-6-0-1-tp6600286p6606885.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
