[mapserver-users] Problem GetFeature with geom filter on WFS
Steve Lime sdlime at gmail.com
Mon Jul 25 10:40:24 EDT 2011
Hi Stéphane: What MapServer version? Does the filter fail against a
shapefile version of the data as well?
Steve
On Mon, Jul 25, 2011 at 6:19 AM, Stéphane Brunner <
stephane.brunner at camptocamp.com> wrote:
> Hello,
> I have the mapfile [0]. when I done a GetFeature on the nummer [1] I
> have 4 results [2] (with duplicate but it's an other issue).
> When I done a spatial filter [3] I have no results [4] but I should
> have at least one result ...
> Thanks in advance for having a look on this issue.
> Sincerely yours
> Stéphane Brunner
> Following: specified, GetCapabilities [5], describefeaturetype [6].
> mapfile [0]:
> MAP
>    NAME "map"
>    EXTENT 620000 218000 690000 278000
>    UNITS METERS
>    IMAGETYPE jpeg
>    RESOLUTION 72
>    DEFRESOLUTION 72
>    IMAGECOLOR 255 255 255
>    STATUS ON
>    FONTSET "fonts.conf"
>    SYMBOLSET "symbole.sym"
>    MAXSIZE 5000
>    PROJECTION
>        "init=epsg:21781"
>    END
>    # Used by overlays
>    OUTPUTFORMAT
>        NAME png256
>        DRIVER AGG/PNG
>        MIMETYPE "image/png256"
>        IMAGEMODE RGBA
>        EXTENSION "png"
>        FORMATOPTION "INTERLACE=OFF"
>        FORMATOPTION "QUANTIZE_FORCE=ON"
>        FORMATOPTION "QUANTIZE_DITHER=OFF"
>        FORMATOPTION "QUANTIZE_COLORS=256"
>    END
>    OUTPUTFORMAT
>        NAME png
>        DRIVER AGG/PNG
>        MIMETYPE "image/png"
>        IMAGEMODE RGBA
>        EXTENSION "png"
>    END
>    WEB
>        METADATA
>            "ows_title" "map"
>            "ows_srs" "epsg:21781"
>            "ows_encoding" "UTF-8"
>            "wms_feature_info_mime_type" "application/vnd.ogc.gml"
>            "wms_enable_request" "*"
>            "ows_enable_request" "*"
>            "gml_include_items" "all"
>            "gml_featureid" "id"
>            "wfs_title" "map"
>            "wfs_srs" "epsg:21781"
>        END
>        IMAGEPATH '/var/tmp/'
>    END
>    LEGEND
>        IMAGECOLOR 240 240 240
>        LABEL
>            FONT arial
>            ANTIALIAS true
>            TYPE truetype
>            SIZE 9
>            COLOR 0 0 0
>        END
>    END
> LAYER
>  NAME "Liegenschaft_Query"
>  TYPE POLYGON
>  STATUS ON
>  TEMPLATE fooOnlyForWMSGetFeatureInfo
>  CONNECTIONTYPE postgis
>  PROCESSING "CLOSE_CONNECTION=DEFER"
>  CONNECTION "user=www-data password=www-data dbname=dev host=localhost"
>  DATA "geom from (SELECT oid, t1.geom, t1.nummer FROM
> av.view_i_liegenschaft_all AS t1) AS foo using unique oid using
> SRID=-1"
> #  GROUP "TOPIC_Liegenschaften_LN"
>  METADATA
>    "ows_title" "Liegenschaft_Query"
>    "id_attribute_string" "oid"
>    "ows_featureid" "oid"
>    "ows_geometries" "geom"
>    "ows_geom_type" "polygon"
>    "query_returned_attributes" "nummer"
>    "gml_include_items" "oid,nummer,geom"
>    "gml_geometries" "geom"
>    "gml_geom_type" "polygon"
>    "gml_nummer_type" "Character"
>    #"gml_groups" "TOPIC_Liegenschaften_LN"
>    "gml_featureid" "oid"
>    "wfs_title" "Liegenschaft_Query"
>  END
>  DUMP TRUE
>  PROJECTION
>      "init=epsg:21781"
>  END
>  CLASS
>    NAME "Liegenschaft"
>    STYLE
>      SYMBOL "circle"
>      SIZE 3
>      OUTLINECOLOR 0 0 0
>    END
>  END
> END
> END
> query on the nummer [1]:
> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.0.0" maxFeatures="100"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <wfs:Query typeName="feature:Liegenschaft_Query"
> xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:PropertyIsEqualTo>
> <ogc:PropertyName>nummer</ogc:PropertyName>
> <ogc:Literal>3634</ogc:Literal>
> </ogc:PropertyIsEqualTo>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> response on the nummer [2]:
> <?xml version='1.0' encoding="UTF-8" ?>
> <wfs:FeatureCollection
>   xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>   xmlns:gml="http://www.opengis.net/gml"
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://c2cpc89.camptocamp.com/sbrunner/mapserv?SERVICE=WFS&amp;VERSION=1.0.0&amp;REQUEST=DescribeFeatureType&amp;TYPENAME=feature:Liegenschaft_Query&amp;OUTPUTFORMAT=XMLSCHEMA
>      <gml:boundedBy>
>        <gml:Box srsName="EPSG:21781">
>                <gml:coordinates>661054.808000,244611.321000
> 663053.704000,244888.622000</gml:coordinates>
>        </gml:Box>
>      </gml:boundedBy>
>    <gml:featureMember>
>      <ms:Liegenschaft_Query fid="Liegenschaft_Query.2380997">
>        <gml:boundedBy>
>                        <gml:coordinates>661054.808000,244854.251000
> 661088.687000,244888.622000</gml:coordinates>
>                </gml:Box>
>        </gml:boundedBy>
>        <ms:geom>
>        <gml:Polygon srsName="EPSG:21781">
>          <gml:outerBoundaryIs>
>            <gml:LinearRing>
>              <gml:coordinates>661076.579000,244888.622000
> 661054.808000,244875.484000 661062.744000,244858.448000
> 661064.653000,244854.251000 661088.687000,244869.173000
> 661076.579000,244888.622000 </gml:coordinates>
>            </gml:LinearRing>
>          </gml:outerBoundaryIs>
>        </gml:Polygon>
>        </ms:geom>
>        <ms:oid>2380997</ms:oid>
>        <ms:nummer>3634</ms:nummer>
>      </ms:Liegenschaft_Query>
>    </gml:featureMember>
>    <gml:featureMember>
>        <gml:boundedBy>
>                </gml:Box>
>        </gml:boundedBy>
>        <ms:geom>
>            <gml:LinearRing>
>            </gml:LinearRing>
>        </gml:Polygon>
>        </ms:geom>
>    <gml:featureMember>
>      <ms:Liegenschaft_Query fid="Liegenschaft_Query.2384539">
>        <gml:boundedBy>
>                        <gml:coordinates>663017.565000,244611.321000
> 663053.704000,244650.084000</gml:coordinates>
>                </gml:Box>
>        </gml:boundedBy>
>        <ms:geom>
>            <gml:LinearRing>
>              <gml:coordinates>663017.565000,244635.722000
> 663033.235000,244611.321000 663045.949000,244619.485000
> 663053.704000,244626.417000 663034.337000,244650.084000
> 663017.565000,244635.722000 </gml:coordinates>
>            </gml:LinearRing>
>        </gml:Polygon>
>        </ms:geom>
>        <ms:oid>2384539</ms:oid>
>    <gml:featureMember>
>        <gml:boundedBy>
>                </gml:Box>
>        </gml:boundedBy>
>        <ms:geom>
>            <gml:LinearRing>
>            </gml:LinearRing>
>        </gml:Polygon>
>        </ms:geom>
> </wfs:FeatureCollection>
> query with spatial filter [3]:
> <ogc:Intersects>
> <ogc:PropertyName>geom</ogc:PropertyName>
> <gml:Point xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:21781">
> <gml:coordinates decimal="." cs="," ts="
> ">661070.024,244872.084</gml:coordinates>
> </gml:Point>
> </ogc:Intersects>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> response with spatial filter [4]:
>   <gml:boundedBy>
>      <gml:null>missing</gml:null>
>   </gml:boundedBy>
> GetCapabilities [5]:
> <WFS_Capabilities
>   version="1.0.0"
>   updateSequence="0"
>   xmlns="http://www.opengis.net/wfs"
> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
> <!-- MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE -->
> <Service>
>  <Name>MapServer WFS</Name>
>  <Title>Amtliche Vermessung</Title>
>  <Abstract>Die amtliche Vermessung nach DM01 Darstellung als WMS
> Dienst für MapFish Projekte</Abstract>
>  <OnlineResource>http://c2cpc89.camptocamp.com/sbrunner/mapserv
> ?</OnlineResource>
> </Service>
> <Capability>
>  <Request>
>    <GetCapabilities>
>      <DCPType>
>        <HTTP>
>          <Get onlineResource="
> http://c2cpc89.camptocamp.com/sbrunner/mapserv?"
>        </HTTP>
>      </DCPType>
>      <DCPType>
>        <HTTP>
>          <Post
> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?" />
>        </HTTP>
>      </DCPType>
>    </GetCapabilities>
>    <DescribeFeatureType>
>      <SchemaDescriptionLanguage>
>        <XMLSCHEMA/>
>      </SchemaDescriptionLanguage>
>      <DCPType>
>        <HTTP>
>        </HTTP>
>      </DCPType>
>      <DCPType>
>        <HTTP>
>          <Post
>        </HTTP>
>      </DCPType>
>    </DescribeFeatureType>
>    <GetFeature>
>      <ResultFormat>
>        <GML2/>
>      </ResultFormat>
>      <DCPType>
>        <HTTP>
>        </HTTP>
>      </DCPType>
>      <DCPType>
>        <HTTP>
>          <Post
>        </HTTP>
>      </DCPType>
>    </GetFeature>
>  </Request>
> </Capability>
> <FeatureTypeList>
>  <Operations>
>    <Query/>
>  </Operations>
>    <FeatureType>
>        <Name>Liegenschaft_Query</Name>
>        <Title>Liegenschaft_Query</Title>
>        <SRS>epsg:21781</SRS>
>        <LatLongBoundingBox minx="620000" miny="218000" maxx="690000"
> maxy="278000" />
>    </FeatureType>
>    <FeatureType>
>        <Name>Liegenschaft_Query_ALL</Name>
>        <Title>Liegenschaft_Query_ALL</Title>
> maxy="278000" />
>    </FeatureType>
> </FeatureTypeList>
> <ogc:Filter_Capabilities>
>  <ogc:Spatial_Capabilities>
>    <ogc:Spatial_Operators>
>      <ogc:Equals/>
>      <ogc:Disjoint/>
>      <ogc:Touches/>
>      <ogc:Within/>
>      <ogc:Overlaps/>
>      <ogc:Crosses/>
>      <ogc:Intersect/>
>      <ogc:Contains/>
>      <ogc:DWithin/>
>      <ogc:BBOX/>
>    </ogc:Spatial_Operators>
>  </ogc:Spatial_Capabilities>
>  <ogc:Scalar_Capabilities>
>    <ogc:Logical_Operators />
>    <ogc:Comparison_Operators>
>      <ogc:Simple_Comparisons />
>      <ogc:Like />
>      <ogc:Between />
>    </ogc:Comparison_Operators>
>  </ogc:Scalar_Capabilities>
> </ogc:Filter_Capabilities>
> </WFS_Capabilities>
> describefeaturetype [6]:
> <schema
>   targetNamespace="http://mapserver.gis.umn.edu/mapserver"
>   xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>   xmlns="http://www.w3.org/2001/XMLSchema"
>   elementFormDefault="qualified" version="0.1" >
>  <import namespace="http://www.opengis.net/gml"
>          schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"
>  <element name="Liegenschaft_Query"
>           type="ms:Liegenschaft_QueryType"
>           substitutionGroup="gml:_Feature" />
>  <complexType name="Liegenschaft_QueryType">
>    <complexContent>
>      <extension base="gml:AbstractFeatureType">
>        <sequence>
>          <element name="geom" type="gml:PolygonPropertyType"
> minOccurs="0" maxOccurs="1"/>
>          <element name="oid" type="string"/>
>          <element name="nummer" type="Character"/>
>        </sequence>
>      </extension>
>    </complexContent>
>  </complexType>
> </schema>
> camptocamp.com
> mapfish.org
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110725/067a882a/attachment-0001.html
