[mapserver-users] Fw: mapserver-users Digest, Vol 42, Issue 60
Tom van der Putte
tom at vdputte.nl
Tue Jul 26 07:21:29 EDT 2011
uur p
Verzonden vanaf Samsung Mobile
-------- Oorspronkelijk bericht --------
Onderwerp: mapserver-users Digest, Vol 42, Issue 60
Van: mapserver-users-request at lists.osgeo.org
Aan: mapserver-users at lists.osgeo.org
Cc:
Send mapserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/mapserver-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
mapserver-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of mapserver-users digest..."
Today's Topics:
1. Re: How to convert from 2393(Finish YKJ) to 4326 (WGS84)
(Rahkonen Jukka)
2. Question: loadWeb(): Unknown identifier. Parsing error near
(ms_tmp):(line 36) (Mihaela Caluian)
3. Re: Question: loadWeb(): Unknown identifier. Parsing error
near (ms_tmp):(line 36) (Steve Lime)
4. Fw: Re: [mapserver-users] How to convert from 2393(Finish
YKJ) to 4326 (WGS84) (Pena Kupen)
Message: 1
Date: Sun, 24 Jul 2011 17:16:46 +0000
From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
Subject: Re: [mapserver-users] How to convert from 2393(Finish YKJ) to
4326 (WGS84)
To: Pena Kupen <kupen at wippies.fi>, "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Message-ID:
<84446DEF76453C439E9E97E438E13A63015546 at suutari.haapa.mmm.fi>
Content-Type: text/plain; charset="iso-8859-1"
I suppose that towgs84 parameters are missing. You can check this with psql:
select proj4text from spatial_ref_sys where srid=2393;
The result should be close to
+proj=tmerc +lat_0=0 +lon_0=27 +k=1.000000 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-90.7,-106.1,-119.2,4.09,0.218,-1.05,1.37 +units=m +no_defs
If it is not, update the record.
A related thing is that Mapserver epsg text file often comes without towgs84 parameters for the Finnish KKJ zones. This is what I seem to have on this computer:
KKJ / Finland Uniform Coordinate System
<2393> +proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.0617,-82.4278,-121.743,4.80107,0.34543,-1.37646,1.4964 +units=m +no_defs <>
You can see that the parameters are not the same. There are more parameter sets around and that's actually the reason why Proj4 comes or at least used to come without any parameters because none of the sets was authorized. The results of these transformations are rather close and accurate to about one meter. You can read also http://latuviitta.org/documents/YKJ-TM35FIN_muunnos_ogr2ogr_cs2cs.txt (in Finnish, I suppose it is not a problem for you).
-Jukka Rahkonen-
Pena Kupen wrote:
> Hello all,
> Last time I was successfully helped by Ralf - Thank's once more time!
http://postgis.refractions.net/pipermail/postgis-users/2011-March/029055.html
> Now I have same type of problem, but I cannot get correct result.
Table is:
CREATE TABLE location (
location_id integer NOT NULL,
coord geometry
Data is in coord column as 2393 format.
My sql is like:
select
y(location.coord) as y_ykj,
x(location.coord) as x_ykj,
y(ST_Transform(location.coord,4326)) as y_wgs84,
x(ST_Transform(location.coord,4326)) as x_wgs84
from location where location_id = 'AAA123A'
result for y_ykj and x_ykj are ok, but point of x_wgs84 and y_wgs84 are about 180meters too much in east.
-Pena
Wippies-vallankumous on t��ll�! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
http://www.wippies.com/
Message: 2
Date: Mon, 25 Jul 2011 00:14:20 -0400
From: Mihaela Caluian <mihaela.caluian at gmail.com>
Subject: [mapserver-users] Question: loadWeb(): Unknown identifier.
Parsing error near (ms_tmp):(line 36)
To: mapserver-users at lists.osgeo.org
Message-ID:
<CAFJRrfRVVA98mPiczXk1-A_oqv_J8Ztmk=1C3enWA4iriBnByw at mail.gmail.com>
Hello everybody,
I am very new to MapServer and I have a lots of problem that I cannot find
answer.
Currently I am having trouble to figure out what is wrong with my .map
files. I am getting this error when I try to click the button to load the
map file:
loadWeb(): Unknown identifier. Parsing error near (ms_tmp):(line 49)
msOutputFormatValidate(): General error message. OUTPUTFORMAT png has
IMAGEMODE RGB/RGBA, which is not supported for GD drivers.
When I installed for the first time MapServer everything works, but I had to
reinstall it and I cannot even see my work now.
I am using Windows Vista and MapServer MS4W - MapServer 4 Windows - version
3.0.3: (This is my first time when I am working with MapServer, actually I
am learning it.)
The map file that I tried to open is:
MAP
NAME "Rail"
# Map image size
SIZE 600 400
UNITS meters
EXTENT -132.193287 28.711430 -50.854471 74.207982
FONTSET 'c:/wwwroot/fonts/fontset.txt'
SYMBOLSET 'c:/wwwroot/symbols/symbols.txt'
PROJECTION
'proj=longlat'
'ellps=WGS84'
'towgs84=0,0,0,0,0,0,0'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGBA
EXTENSION 'png'
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH "\ms4w\tmp\ms_tmp\"
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL "/ms_tmp/"
# WMS server settings
METADATA
'ows_title' 'Rail'
'ows_onlineresource' '
http://localhost/cgi-bin/mapserv.exe?map=C:/wwwroot/assignment3/rail.map'
'ows_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See
TEMPLATE 'rail.html'
END
LAYER
NAME 'Rails'
TYPE LINE
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
DATA 'C:\wwwroot\assignment3\rails.shp'
METADATA
'ows_title' 'Rails'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'no_defs'
END
CLASS
NAME 'Rails'
STYLE
WIDTH 2
COLOR 146 154 155
END
END
END
END
Please, if somebody can help me I will really appreciate. I tried so many
times and now I really don't know what to do more.
Thanks.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110725/17503ec1/attachment-0001.html
Message: 3
Date: Sun, 24 Jul 2011 23:30:04 -0500
Subject: Re: [mapserver-users] Question: loadWeb(): Unknown
identifier. Parsing error near (ms_tmp):(line 36)
To: Mihaela Caluian <mihaela.caluian at gmail.com>
Cc: mapserver-users at lists.osgeo.org
Message-ID:
<CAMrKZ98kBJVtcazecaHNcv5TkcF-dRKxthoTaNh8cAa_uqgkjA at mail.gmail.com>
In MapServer 6.0, the GD driver can only produce 8-bit output so your output
format is invalid. Try commenting it out and see what happens. I believe you
can leave "IMAGETYPE png" in place and you'll get AGG-based, 8-bit output.
Should look much nicer.
Steve
On Sun, Jul 24, 2011 at 11:14 PM, Mihaela Caluian <mihaela.caluian at gmail.com
> wrote:
> Hello everybody,
> answer.
> map file:
> to reinstall it and I cannot even see my work now.
> am learning it.)
> MAP
> NAME "Rail"
> # Map image size
> SIZE 600 400
> UNITS meters
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'no_defs'
> END
> IMAGEQUALITY 95
> IMAGETYPE png
> OUTPUTFORMAT
> NAME png
> DRIVER 'GD/PNG'
> IMAGEMODE RGBA
> EXTENSION 'png'
> END
> # Legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> WEB
> # write its output.
> IMAGEURL "/ms_tmp/"
> METADATA
> 'ows_title' 'Rail'
> END
> END
> LAYER
> NAME 'Rails'
> TYPE LINE
> DUMP true
> METADATA
> 'ows_title' 'Rails'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'no_defs'
> END
> CLASS
> NAME 'Rails'
> STYLE
> WIDTH 2
> COLOR 146 154 155
> END
> END
> END
> END
> Thanks.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110724/e87a2a06/attachment-0001.html
Message: 4
Date: Mon, 25 Jul 2011 08:54:03 +0300 (EEST)
Subject: Fw: Re: [mapserver-users] How to convert from 2393(Finish
Message-ID: <1134235633.2761311573244115.JavaMail.kupen at wippies.fi>
Content-Type: text/plain; Charset=iso-8859-1; Format=Flowed
Thank's Jukka,
On my spatial_ref_sys-table, there is proj4text like:
+proj=tmerc +lat_0=0 +lon_0=27 +k=1.000000 +x_0=3500000 +y_0=0 +ellps=intl +units=m +no_defs
So towgs84-parameter is missing.
It this safe? Can it affect with unwanted result somewhere?
Yeps, language not, but understanding is something else ;-)
-Pena
Rahkonen Jukka [Jukka.Rahkonen at mmmtike.fi] kirjoitti:
> Hi,
> -Jukka Rahkonen-
> Pena Kupen wrote:
> > Hello all,
> Table is:
> coord geometry
> My sql is like:
> select
> -Pena
End of mapserver-users Digest, Vol 42, Issue 60
