[mapserver-users] map server a tile server
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jul 26 16:22:50 EDT 2011
On 7/26/2011 4:15 PM, jk wrote:
> Hi,
> I'm not very clear about the concept of map server v.s. tile server. Can a
> map server be used as a mip server? Is that a normal way of doing tile
> server.
> Here is what I have,
> I have a collection of NATIF files that I need to serve them in a map client
> (in OpenLayers, via WMS), sevring these cadrg files as base map. In other
> words, these CADRG files together is the base map. Clients will zoom, in
> and out, pam, and so on.
> How do I make a base map? Use Map Server? Use gdaltinex commnad? shpe file?
> And, I need it to serve with WMS commands
> Anyone please help with your idea.
Here is one basic scenario. part of your confusion might be because tile
means different thing s in different contexts.
1. use gdaltindex to create a tileindex that can be used by mapserver.
The tile index basically lets mapserver deal with your collection of
files a a single virtual layer.
2. create a mapfile to display your base layer using the tileindex and
make the mapfile support WMS requests.
* at this point you should be able to setup OpenLayers as a WMS layer
can display your base layer. This might be enough for you, but is
rendering the base layer is too slow, then you can look at ways to
optimize the performance and/or you can setup a tile cache server that
uses the mapserver WMS to seed the tilecache as needed. This requires a
lot more disk space, but once the tiles are in the cache they serve and
load very fast like google.
3. look at mod_geocache if you want to setup a tilecache. All you would
need to do on Linux is download the source, compile it, install it in
apache2 and edit the config file and it has a demo mode if you add it to
the config
http://yourhost/geocache/demo
and it will generate a simple OpenLayers app the displays your tile from
the cache as a baselayer.
-Steve W
