[mapserver-users] Possible Bug? use Style with Offset and Colorfrom DB twice in one class section
Ralf Trier Ralf.Trier at logos-ib.de
Thu Jul 28 01:57:06 EDT 2011
Hi Steve,
I use Version 6.0.0.
Ralf
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] Im Auftrag von Steve Lime
> Gesendet: Donnerstag, 28. Juli 2011 06:02
> An: Ralf Trier
> Cc: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Possible Bug? use Style with Offset and
> What version? I remember fixing something like this at one point...
> Steve
> Sent from my iPad
> On Jul 26, 2011, at 4:13 AM, "Ralf Trier" <Ralf.Trier at logos-ib.de>
> wrote:
> > Hello,
> > I want to draw two parallel lines to baselines from a database. The
> > parallel lines should be drawn with the color set in the db.
> > Part of my map file:
> > LAYER
> >    NAME "tttt"
> >    TYPE LINE
> >    PROJECTION
> >        "init=epsg:900913"
> >    END
> >    STATUS DEFAULT
> >    CONNECTIONTYPE postgis
> >    CONNECTION "host=192.168.1.10 dbname=xxx user=xxx"
> >    DATA "way from (select id, color01, color02, way from myTable)
> > as foo using unique id using srid=900913"
> >    SIZEUNITS pixels
> >    CLASS
> >        STYLE
> >            OFFSET 5 -99
> >            COLOR [color01]
> >            WIDTH 10
> >            LINECAP square
> >        END
> >        STYLE
> >            OFFSET -5 -99
> >            COLOR [color02]
> >            WIDTH 10
> >            LINECAP square
> >        END
> >    END
> > END
> > Strange think happens. The first parallel line is drawn with the
> > expected color. The second line (second style instruction) will be
> drawn
> > in a random color seems to come from another line. The color (second
> > line) will change depending form the scale.
> > Any ideas?
> > Thanks
> > Ralf
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
