[mapserver-users] Plotting points as a line from sqlite database
Fawcett, David (MPCA)
david.fawcett at state.mn.us
Thu Jul 28 14:39:27 EDT 2011
Ian,
Take a look at 2.4.0-RC5
http://www.gaia-gis.it/spatialite-2.4.0-5/spatialite-sql-2.4-5.html#p5
Look under "SQL utility functions [non-standard] for geometric objects"
David.
-----Original Message-----
From: Ian Walberg [mailto:ian.walberg at airborne.aero]
Sent: Thursday, July 28, 2011 12:41 PM
To: Fawcett, David (MPCA); Stephen Woodbridge; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Plotting points as a line from sqlite database
Gents,
Thanks for these ideas, however I cannot seem to find a MakeLine
function in spatialite 2.4.0.
Where should I be looking?
Thanks
Ian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Fawcett,
David (MPCA)
Sent: Thursday, June 30, 2011 6:44 AM
To: Stephen Woodbridge; mapserver-users at lists.osgeo.org
database
ST_MAKELINE() does exist in recent versions of Spatialite.
It doesn't appear to have made it in to the docs, but it can be seen in
this example from the cookbook.
http://www.gaia-gis.it/spatialite-2.4.0-4/spatialite-cookbook/html/pp-ad
jacent.html
Another example is in this thread from the Spatialite list:
http://groups.google.com/group/spatialite-users/browse_thread/thread/002
0f8e907ae9226
You will likely need recent versions of both Spatialite and OGR to make
it work.
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Wednesday, June 29, 2011 10:49 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Plotting points as a line from sqlite
database
On 6/29/2011 10:13 PM, Ian Walberg wrote:
> I hope this isn't too stupid a question.
> Would like to display a list of positions in an sqlite database as a
> line, to show the flight path of an aircraft. The data is in the db as
> Lat, Long and point (lat, long)
> We can display the positions as individual dots but not as a line, I
> fear the problem is that the data is a point.
> As the data is being accumulated we would prefer not to create a new
> line in the database each time if possible.
> Any suggestions to what options we have would be appreciated.
Hi Ian,
In postgis there is an aggregrate function makeline() that you can feed
points to. I think there may be an equivalent function in SpatiaLite.
In sqlite, you might be able to use a group_concat() something like:
select 'LINESTRING('|| group_concat(lat||' '||long, ',') ||')'
from points;
But I think the issue will be that this is not a format that mapserver
understands. You might be able to access this via GDAL/OGR but I'm not
sure on that.
-Steve W
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
