[mapserver-users] Re: Is it posible to substitute a value from
table for width of line
thomas bonfort
thomas.bonfort at gmail.com
Wed Jun 1 04:54:38 EDT 2011
then make sure you are actually using 5.2.1 and not an older version
On Wed, Jun 1, 2011 at 10:47, prab.raja <prab.raja at gmail.com> wrote:
> yes.
> Below is the style copied from my Map file.
> STYLE
> COLOR 0 140 70
> WIDTH [gid]
> END
> On Wed, Jun 1, 2011 at 2:12 PM, thomas bonfort [via OSGeo.org] <[hidden
> email]> wrote:
>> are you using the exact syntax of your first example, i.e. "WIDTH [gid]" ?
>> On Wed, Jun 1, 2011 at 10:27, prab.raja <[hidden email]> wrote:
>> > But when I tried this mapserver gives error message as "getInteger():
>> > Symbol
>> > definition error. Parsing error near (gid)".
>> > I am using MapServer version 5.2.1.
>> > On Wed, Jun 1, 2011 at 1:48 PM, Havard Tveite [via OSGeo.org] <[hidden
>> > email]> wrote:
>> >> According to <URL: <a
>> >> href="http://www.mapserver.org/mapfile/style.html ">http://www.mapserver.org/mapfile/style.html >
>> >> that should be possible.
>> >> Håvard
>> >> On 6/1/2011 8:09 AM, prab.raja wrote:
>> >> > Hi,
>> >> > I would like to know if it's posible to draw line layer with variable
>> >> > width
>> >> > from database table.
>> >> > Something like this?
>> >> > LAYER
>> >> > NAME line_layer
>> >> > CONNECTIONTYPE postgis
>> >> > CONNECTION "user=postgres password=****** dbname=shpdb
>> >> > host=localhost
>> >> > port=5432"
>> >> > DATA "the_geom FROM (SELECT gid, the_geom FROM line_layer)
>> >> > AS SUBQUERY using unique gid"
>> >> > PROCESSING "CLOSE_CONNECTION=DEFER"
>> >> > TYPE line
>> >> > OPACITY 100
>> >> > STATUS Off
>> >> > CLASS
>> >> > STYLE
>> >> > COLOR 0 140 70
>> >> > WIDTH [gid]
>> >> > END
>> >> > END
>> >> > END
>> >> > View this message in context:
>> >> > http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6425708.html
>> >> > Sent from the Mapserver - User mailing list archive at Nabble.com.
>> >> > _______________________________________________
>> >> > mapserver-users mailing list
>> >> > [hidden email]
>> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> Håvard Tveite
>> >> Department of Mathematical Sciences and Technology, UMB
>> >> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> >> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
>> >> [hidden email]
>> >> If you reply to this email, your message will be added to the
>> >> discussion
>> >> below:
>> >> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426034.html
>> >> To unsubscribe from Is it posible to substitute a value from table for
>> >> width of line, click here.
>> > Regards,
>> > Prabu Raja
>> > View this message in context: Re: Is it posible to substitute a value
>> > from
>> > [hidden email]
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426084.html
> Regards,
> Prabu Raja
> View this message in context: Re: Is it posible to substitute a value from
> mapserver-users at lists.osgeo.org
