[mapserver-users] Re: Is it posible to substitute a value from
table for width of line
thomas bonfort
thomas.bonfort at gmail.com
Wed Jun 1 05:04:20 EDT 2011
ok. the docs are wrong. WIDTH binding is available since mapserver 5.4.0.
On Wed, Jun 1, 2011 at 10:58, prab.raja <prab.raja at gmail.com> wrote:
> Below is the mapserv.exe -v output.
> It shows MapServer version 5.2.1 only.
> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICO
> NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUP
> PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> On Wed, Jun 1, 2011 at 2:24 PM, thomas bonfort [via OSGeo.org] <[hidden
> email]> wrote:
>> then make sure you are actually using 5.2.1 and not an older version
>> On Wed, Jun 1, 2011 at 10:47, prab.raja <[hidden email]> wrote:
>> > yes.
>> > Below is the style copied from my Map file.
>> > STYLE
>> > COLOR 0 140 70
>> > WIDTH [gid]
>> > END
>> > On Wed, Jun 1, 2011 at 2:12 PM, thomas bonfort [via OSGeo.org] <[hidden
>> > email]> wrote:
>> >> are you using the exact syntax of your first example, i.e. "WIDTH
>> >> [gid]" ?
>> >> On Wed, Jun 1, 2011 at 10:27, prab.raja <[hidden email]> wrote:
>> >> > But when I tried this mapserver gives error message as "getInteger():
>> >> > Symbol
>> >> > definition error. Parsing error near (gid)".
>> >> > I am using MapServer version 5.2.1.
>> >> > On Wed, Jun 1, 2011 at 1:48 PM, Havard Tveite [via OSGeo.org]
>> >> > <[hidden
>> >> > email]> wrote:
>> >> >> According to <URL: <a
>> >> >> href="<a
>> >> >> href="http://www.mapserver.org/mapfile/style.html ">http://www.mapserver.org/mapfile/style.html "><a
>> >> >> href="http://www.mapserver.org/mapfile/style.html ">http://www.mapserver.org/mapfile/style.html >
>> >> >> that should be possible.
>> >> >> Håvard
>> >> >> On 6/1/2011 8:09 AM, prab.raja wrote:
>> >> >> > Hi,
>> >> >> > I would like to know if it's posible to draw line layer with
>> >> >> > variable
>> >> >> > width
>> >> >> > from database table.
>> >> >> > Something like this?
>> >> >> > LAYER
>> >> >> > NAME line_layer
>> >> >> > CONNECTIONTYPE postgis
>> >> >> > CONNECTION "user=postgres password=****** dbname=shpdb
>> >> >> > host=localhost
>> >> >> > port=5432"
>> >> >> > DATA "the_geom FROM (SELECT gid, the_geom FROM line_layer)
>> >> >> > AS SUBQUERY using unique gid"
>> >> >> > PROCESSING "CLOSE_CONNECTION=DEFER"
>> >> >> > TYPE line
>> >> >> > OPACITY 100
>> >> >> > STATUS Off
>> >> >> > CLASS
>> >> >> > STYLE
>> >> >> > COLOR 0 140 70
>> >> >> > WIDTH [gid]
>> >> >> > END
>> >> >> > END
>> >> >> > END
>> >> >> > View this message in context:
>> >> >> > http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6425708.html
>> >> >> > Sent from the Mapserver - User mailing list archive at Nabble.com.
>> >> >> > _______________________________________________
>> >> >> > mapserver-users mailing list
>> >> >> > [hidden email]
>> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> >> Håvard Tveite
>> >> >> Department of Mathematical Sciences and Technology, UMB
>> >> >> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> >> >> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
>> >> >> [hidden email]
>> >> >> If you reply to this email, your message will be added to the
>> >> >> discussion
>> >> >> below:
>> >> >> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426034.html
>> >> >> To unsubscribe from Is it posible to substitute a value from table
>> >> >> for
>> >> >> width of line, click here.
>> >> > Regards,
>> >> > Prabu Raja
>> >> > View this message in context: Re: Is it posible to substitute a value
>> >> > from
>> >> > [hidden email]
>> >> [hidden email]
>> >> discussion
>> >> below:
>> >> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426084.html
>> >> To unsubscribe from Is it posible to substitute a value from table for
>> > Regards,
>> > Prabu Raja
>> > from
>> > [hidden email]
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426114.html
> Regards,
> Prabu Raja
> View this message in context: Re: Is it posible to substitute a value from
> mapserver-users at lists.osgeo.org
