[mapserver-users] Re: HTTP request error. CURLOPT_PROXYAUTH not
supported. Requires Curl 7.10.7 and up
thomas bonfort
thomas.bonfort at gmail.com
Wed Jun 1 05:34:19 EDT 2011
looking at the code, it seems the only reason on unix you'd get that
message is because the curl library is too old. On ms4w it might be
because the maintainer has not set the USE_CURLOPT_PROXYAUTH #define.
thomas
On Wed, Jun 1, 2011 at 11:26, sulu <andreas.siegel at vorarlberg.at> wrote:
> Hi Jukka.
> Thanks for answering.
> If i use only wms_proxy_host and wms_proxy_port parameter in the
> Layer/Metadata i get a plain old 407 because of missing credentials.
> But if wms_proxy_password comes into use the "CURLOPT_PROXYAUTH not
> supported"-error shows up.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/HTTP-request-error-CURLOPT-PROXYAUTH-not-supported-Requires-Curl-7-10-7-and-up-tp6421746p6426206.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
