[mapserver-users] Re: Is it posible to substitute a value from table for width of line
Brent Fraser bfraser at geoanalytic.com
Wed Jun 1 09:37:19 EDT 2011
There's even a ticket:
http://trac.osgeo.org/mapserver/ticket/3448
Best Regards,
Brent Fraser
On 6/1/2011 3:18 AM, prab.raja wrote:
> OK. Thanks!
> On Wed, Jun 1, 2011 at 2:34 PM, thomas bonfort [via OSGeo.org]
> <[hidden email] </user/SendEmail.jtp?type=node&node=6426184&i=0>> wrote:
>     ok. the docs are wrong. WIDTH binding is available since mapserver
>     5.4.0.
>     On Wed, Jun 1, 2011 at 10:58, prab.raja <[hidden email]
>     <http://user/SendEmail.jtp?type=node&node=6426142&i=0>> wrote:
>     > Below is the mapserv.exe -v output.
>     > It shows MapServer version 5.2.1 only.
>     > MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>     OUTPUT=WBMP
>     > OUTPUT=PDF
>     >  OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>     > SUPPORTS=ICO
>     > NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>     > SUPPORTS=WFS_SERVER
>     > SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>     SUPPORTS=FASTCGI
>     > SUP
>     > PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG
>     INPUT=POSTGIS
>     > INPUT=OGR
>     >  INPUT=GDAL INPUT=SHAPEFILE
>     > On Wed, Jun 1, 2011 at 2:24 PM, thomas bonfort [via OSGeo.org]
>     <[hidden
>     > email]> wrote:
>     >> then make sure you are actually using 5.2.1 and not an older
>     version
>     >> On Wed, Jun 1, 2011 at 10:47, prab.raja <[hidden email]> wrote:
>     >> > yes.
>     >> > Below is the style copied from my Map file.
>     >> >         STYLE
>     >> >             COLOR 0 140 70
>     >> >             WIDTH [gid]
>     >> >          END
>     >> > On Wed, Jun 1, 2011 at 2:12 PM, thomas bonfort [via
>     OSGeo.org] <[hidden
>     >> > email]> wrote:
>     >> >> are you using the exact syntax of your first example, i.e.
>     "WIDTH
>     >> >> [gid]" ?
>     >> >> On Wed, Jun 1, 2011 at 10:27, prab.raja <[hidden email]> wrote:
>     >> >> > But when I tried this mapserver gives error message as
>     "getInteger():
>     >> >> > Symbol
>     >> >> > definition error. Parsing error near (gid)".
>     >> >> > I am using MapServer version 5.2.1.
>     >> >> > On Wed, Jun 1, 2011 at 1:48 PM, Havard Tveite [via OSGeo.org]
>     >> >> > <[hidden
>     >> >> > email]> wrote:
>     >> >> >> According to <URL: <a
>     >> >> >> href="<a
>     >> >> >> href="<a
>     href="http://www.mapserver.org/mapfile/style.html ">http://www.mapserver.org/mapfile/style.html "><a
>     >> >> >> href="<a
>     >> >> >> that should be possible.
>     >> >> >> Håvard
>     >> >> >> On 6/1/2011 8:09 AM, prab.raja wrote:
>     >> >> >> > Hi,
>     >> >> >> > I would like to know if it's posible to draw line layer
>     with
>     >> >> >> > variable
>     >> >> >> > width
>     >> >> >> > from database table.
>     >> >> >> > Something like this?
>     >> >> >> > LAYER
>     >> >> >> >        NAME line_layer
>     >> >> >> >        CONNECTIONTYPE postgis
>     >> >> >> >        CONNECTION "user=postgres password=******
>     dbname=shpdb
>     >> >> >> > host=localhost
>     >> >> >> > port=5432"
>     >> >> >> >        DATA "the_geom FROM  (SELECT gid, the_geom FROM
>     line_layer)
>     >> >> >> >           AS SUBQUERY using unique gid"
>     >> >> >> >        PROCESSING "CLOSE_CONNECTION=DEFER"
>     >> >> >> >        TYPE line
>     >> >> >> >        OPACITY 100
>     >> >> >> >        STATUS Off
>     >> >> >> >        CLASS
>     >> >> >> >           STYLE
>     >> >> >> >              COLOR 0 140 70
>     >> >> >> >              WIDTH [gid]
>     >> >> >> >           END
>     >> >> >> >        END
>     >> >> >> >     END
>     >> >> >> > View this message in context:
>     http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6425708.html
>     >> >> >> > Sent from the Mapserver - User mailing list archive at
>     Nabble.com.
>     >> >> >> > _______________________________________________
>     >> >> >> > mapserver-users mailing list
>     >> >> >> > [hidden email]
>     >> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>     >> >> >> Håvard Tveite
>     >> >> >> Department of Mathematical Sciences and Technology, UMB
>     >> >> >> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>     >> >> >> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
>     >> >> >> [hidden email]
>     >> >> >> If you reply to this email, your message will be added to
>     the
>     >> >> >> discussion
>     >> >> >> below:
>     http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426034.html
>     >> >> >> To unsubscribe from Is it posible to substitute a value
>     from table
>     >> >> >> for
>     >> >> >> width of line, click here.
>     >> >> > Regards,
>     >> >> > Prabu Raja
>     >> >> > View this message in context: Re: Is it posible to
>     substitute a value
>     >> >> > from
>     Nabble.com.
>     >> >> > [hidden email]
>     >> >> [hidden email]
>     >> >> If you reply to this email, your message will be added to the
>     >> >> discussion
>     >> >> below:
>     http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426084.html
>     >> >> To unsubscribe from Is it posible to substitute a value from
>     table for
>     >> > Regards,
>     >> > Prabu Raja
>     >> > View this message in context: Re: Is it posible to substitute
>     a value
>     >> > from
>     Nabble.com.
>     >> > [hidden email]
>     >> [hidden email]
>     discussion
>     >> below:
>     http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426114.html
>     table for
>     > Regards,
>     > Prabu Raja
>     > View this message in context: Re: Is it posible to substitute a
>     value from
>     > Sent from the Mapserver - User mailing list archive at Nabble.com.
>     > [hidden email]
>     <http://user/SendEmail.jtp?type=node&node=6426142&i=1>
>     [hidden email] <http://user/SendEmail.jtp?type=node&node=6426142&i=2>
>     discussion below:
>     http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426142.html
>     To unsubscribe from Is it posible to substitute a value from table
>     for width of line, click here.
> Regards,
> Prabu Raja
> View this message in context: Re: Is it posible to substitute a value
> <http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426184.html>
> <http://osgeo-org.1803224.n2.nabble.com/Mapserver-User-f1969211.html>
> at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110601/05bd28bc/attachment-0001.html
