[mapserver-users] MapServer and NetCDF with date-time
Mark Jackson mark.jackson at cerc.co.uk
Thu Jun 2 06:37:43 EDT 2011
Hi
Does anyone have any advice on the best way to serve NetCDF floating point
rasters with a date-time dimension?
I want to use MapServer to serve up WMS, WMS-T and WCS from NetCDF 3 and
NetCDF 4. The NetCDF files will be compliant with the CF conventions and
will contain lat, long and date-time with floating-point raster data.
Would MapServer / GDAL support this? I've seen that GDAL supports NetCDF
but it's unclear whether it supports NetCDF 4 and I can't see any mention
of whether it supports WMS-T. Presumably it would need to treat the
date-time data like a tile index. Maybe GDAL could read the NetCDF and
create a tile index for MapServer (in PostGIS?).
I've also found a project which did something very similar called ADAGUC.
These guys wrote their own GDAL driver for NetCDF 4 with lat,long,date-time
and patched MapServer. Would that still be the best approach now? This PDF
describes what they did. I may also contact them directly.
http://adaguc.knmi.nl/contents/documents/workshop2008/presentations/ADAGUC_WS2_20081205_Plieger_deReus.pdf
Does anyone have any advice?
Thanks in advance
Mark
____________________________________________________________
Mark Jackson BSc ARCS MSc
Cambridge Environmental Research Consultants Ltd
3 King's Parade, Cambridge, CB2 1SJ
tel: 01223 357773
fax: 01223 357492
web: www.cerc.co.uk
email: mark.jackson at cerc.co.uk
Cambridge Environmental Research Consultants Ltd. cannot accept any
responsibility for the accuracy or completeness of this message as
it has been transmitted over a public network.
This e-mail and any files transmitted with it are private and intended
solely for the use of the individual or entity to whom they are
addressed. If you are not the intended recipient, this e-mail and any
accompanying files have been transmitted to you in error.  You may not
copy, distribute or make any other use of the information contained in
them.
CERC is a trading name of Cambridge Environmental Research Consultants Ltd,
registered at Cardiff with number 1926883. Registered Office address:
3 Kings Parade, Cambridge, CB2 1SJ.
