[mapserver-users] where is the line ?
Prabu Raja prab.raja at gmail.com
Mon Jun 6 05:39:13 EDT 2011
Ok. You have included the symbols using "SYMBOLSET" keyword.
Problem might be with symbol named 7 or seventh symbol in that
file(./symbols/symbols.txt).
On Mon, Jun 6, 2011 at 3:01 PM, Tonton <to.tonton at gmail.com> wrote:
> ---------- Forwarded message ----------
> From: Prabu Raja <prab.raja at gmail.com>
> Post your mapfile content, show that we can check what's wrong.
> euh
> #debut du fichier
> MAP
> NAME '28811'
> SIZE 640 480
> UNITS METERS
> FONTSET './fonts/fonts.txt'
> SYMBOLSET './symbols/symbols.txt'
> EXTENT 4.65883541107178 45.5676007678223 5.06030035018921 45.9033622741699
> DEBUG ON
> CONFIG "MS_ERRORFILE" "/var/www/tmp/ms_error.txt" #definition de la
> projection de la carte
> PROJECTION
>     "init=epsg:4326"
> END #Projection
>  IMAGETYPE "PNG24"
>  # Debut de la section OUTPUTFORMAT
> OUTPUTFORMAT
>   NAME png
>     DRIVER "GD/PNG"
>     MIMETYPE "image/png"
>     IMAGEMODE PC256
>     EXTENSION 'png'
>  END
>  # debut de la section Web
> WEB
>      MINSCALEDENOM 1000
>     MAXSCALEDENOM 1550000
>  #Modifier cette ligne selon votre installation
>     IMAGEPATH "/var/www/tmp/"
>      IMAGEURL "./tmp/"
> METADATA
>     ows_TITLE "28811"
> ows_ONLINERESOURCE "
> http://192.168.12.60/cgi-bin/mapserv?map=/var/www/mapfile/28811.map"
> "ows_SRS" "EPSG:4326 "
>     ows_ABSTRACT "OWS Geomod webservice "
>  ows_ACCESSCONSTRAINTS "None"
>  END #METADATA
> LOG "./tmp/web.log"
>  END #WEB
>  # debut de Definition de la Couche
> LAYER
> CONNECTIONTYPE postgis
>  CONNECTION "host=localhost dbname=DBname user=USER password=PWD port=5432"
> DATA "geometry FROM tablename"
> NAME "28811"
> TYPE POINT
> DUMP TRUE
>  TRANSPARENCY ALPHA
>  LABELCACHE ON
>     METADATA
>      ows_TITLE "28811"
>     "ows_SRS" "EPSG:4326"
>     "gml_featureid" "gid" ##required
>     "ows_include_items" "nom_stt"
>     "ows_typename" "28811"
>     END #METADATA
> LABELITEM nom_stt
>  STATUS ON
>  Class
>     NAME "28811"
>     STYLE
>     SYMBOL 7
>     SIZE 2
>       OUTLINECOLOR 255 255 255
>     COLOR 192 192 192
>   END #Style
> LABEL
>  FONT arial
>  TYPE truetype
>  ANTIALIAS true
>  MAXSCALEDENOM 92500
> mapserver-users at lists.osgeo.org
Regards,
Prabu Raja
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110606/68e40e83/attachment.html
