[mapserver-users] Openlayers Identify Problem
Matheus Lacarini
matheus.lacarini at sntgeo.com.br
Wed Jun 8 12:30:17 EDT 2011
Hello all,
I´m from Brasil and i have a problem with the openlayers identify my query
its perfect in the mapfile and the layer file but the query result
:msQueryByPoint(): Search returned no results. No matching record(s)
found.My url is : http://localhost/cgi-bin/mapserv.exe?img.x=762
<http://localhost/cgi-bin/mapserv.exe?img.x=762&img.y=433&mode=query&layer=g
tile_topodata&map=C:/var/webmapit/mapserver.d/mapfiles/users/sntgeo/sntgeo-m
ap_004.map&imgext=-104.42206737491+-39.398253504337+-2.9560446250874+11.3982
53504337>
&img.y=433&mode=query&layer=gtile_topodata&map=C:/var/webmapit/mapserver.d/m
apfiles/users/sntgeo/sntgeo-map_004.map&imgext=-104.42206737491+-39.39825350
4337+-2.9560446250874+11.398253504337
Part of my map file :
NAME "sntgeo-map_004_"
EXTENT
-95.883434 -35.000146 -11.494678 7.000146
FONTSET
"/var/webmapit/mapserver.d/fonts/wmi_defaultFontSet.cfg"
CONFIG
"MS_ERRORFILE"
"c:/var/webmapit/mapserver.d/mapfiles/users/sntgeo/sntgeo-map_004.errors.log
DEBUG 5
IMAGETYPE AGGPNG24
MAXSIZE 4096 #--
Larg/Alt maxima da imagem de saida 2384 = A0
SHAPEPATH
"/var/webmapit/mapserver.d/mapfiles/users"
SYMBOLSET
"/var/webmapit/mapserver.d/symbols/wmi_defaultSymbolSet.sym"
UNITS DD
INCLUDE
"/var/webmapit/mapserver.d/mapfiles/include/wmi_map_outputformats.map"
INCLUDE
"/var/webmapit/mapserver.d/mapfiles/include/wmi_projection_4326.map"
WEB
IMAGEPATH
"/var/www/html/tmp/" #--alterar no servidor
IMAGEURL
"/tmp/" #--alterar no servidor
HEADER "topodata_web_header.html"
FOOTER "topodata_web_footer.html"
Layer file:
HEADER
"C:\var\webmapit\mapserver.d\mapfiles\users\sntgeo\topodata_muni_header.html
TEMPLATE
"C:\var\webmapit\mapserver.d\mapfiles\users\sntgeo\topodata_muni_temp.html"
FOOTER
"C:\var\webmapit\mapserver.d\mapfiles\users\sntgeo\topodata_muni_footer.html
END
Índex:
// INI:
http://dev.openlayers.org/releases/OpenLayers-2.10/examples/click-handler.ht
ml
OpenLayers.Control.Click =
OpenLayers.Class(OpenLayers.Control, {
defaultHandlerOptions: {
'single': true,
'double': false,
'pixelTolerance': 0,
'stopSingle': false,
'stopDouble': false
initialize: function(options) {
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
this.handler = new OpenLayers.Handler.Click(
this, {
'click': this.onClick
}, this.handlerOptions
onClick: function(evt) {
var tempXY = explodeArray(evt.xy,',');
var aX = explodeArray(tempXY[0],'=');
var aY = explodeArray(tempXY[1],'=');
var tmpPixel = new OpenLayers.Pixel();
tmpPixel.x = aX[1];
tmpPixel.y = aY[1];
var aLonLat = map.getLonLatFromViewPortPx(tmpPixel);
doIdentify(aLonLat.lon,aLonLat.lat, aX[1], aY[1] );
//alert('X=' + aLonLat.lon + ' Y=' + aLonLat.lat);
var controls;
controls = {
"single": new OpenLayers.Control.Click({
handlerOptions: {
"single": true
var props =
document.getElementById("props");
// FIM:
ml
// INI - do identify...
var control;
for(var key in controls) {
control = controls[key];
// only to route output here
control.key = key;
map.addControl(control);
function toggle(key) {
var control = controls[key];
if(control.active) {
control.deactivate();
} else {
control.activate();
var status = document.getElementById(key + "Status");
status.innerHTML = control.active ? "Navegar" : "Consultar";
What is the problem?
Thanks
Matheus Lacarini
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110608/2bf0c672/attachment-0001.html
