[mapserver-users] ENC: Openlayers Identify Problem
Matheus Lacarini matheus.lacarini at sntgeo.com.br
Thu Jun 9 08:02:47 EDT 2011
Hello all,
I´m from Brasil and i have a problem with the openlayers identify my query
its perfect in the mapfile and the layer file but the query result
:msQueryByPoint(): Search returned no results. No matching record(s)
found.My url is : http://localhost/cgi-bin/mapserv.exe?img.x=762
<http://localhost/cgi-bin/mapserv.exe?img.x=762&img.y=433&mode=query&layer=g
tile_topodata&map=C:/var/webmapit/mapserver.d/mapfiles/users/sntgeo/sntgeo-m
ap_004.map&imgext=-104.42206737491+-39.398253504337+-2.9560446250874+11.3982
53504337>
&img.y=433&mode=query&layer=gtile_topodata&map=C:/var/webmapit/mapserver.d/m
apfiles/users/sntgeo/sntgeo-map_004.map&imgext=-104.42206737491+-39.39825350
4337+-2.9560446250874+11.398253504337
Part of my map file :
NAME                                  "sntgeo-map_004_"
                EXTENT
-95.883434 -35.000146 -11.494678 7.000146
                FONTSET
"/var/webmapit/mapserver.d/fonts/wmi_defaultFontSet.cfg"
                CONFIG
"MS_ERRORFILE"
"c:/var/webmapit/mapserver.d/mapfiles/users/sntgeo/sntgeo-map_004.errors.log
                DEBUG                                5
                IMAGETYPE                       AGGPNG24
                MAXSIZE                                            4096 #--
Larg/Alt maxima da imagem de saida 2384 = A0
                SHAPEPATH
"/var/webmapit/mapserver.d/mapfiles/users"
                SYMBOLSET
"/var/webmapit/mapserver.d/symbols/wmi_defaultSymbolSet.sym"
                UNITS                                  DD
                INCLUDE
"/var/webmapit/mapserver.d/mapfiles/include/wmi_map_outputformats.map"
                INCLUDE
"/var/webmapit/mapserver.d/mapfiles/include/wmi_projection_4326.map"
                     WEB
                               IMAGEPATH
"/var/www/html/tmp/" #--alterar no servidor
                               IMAGEURL
"/tmp/" #--alterar no servidor
                               HEADER  "topodata_web_header.html"
                               FOOTER "topodata_web_footer.html"
Layer file:
                HEADER
"C:\var\webmapit\mapserver.d\mapfiles\users\sntgeo\topodata_muni_header.html
                TEMPLATE
"C:\var\webmapit\mapserver.d\mapfiles\users\sntgeo\topodata_muni_temp.html"
                FOOTER
"C:\var\webmapit\mapserver.d\mapfiles\users\sntgeo\topodata_muni_footer.html
  END
Índex:
 // INI:
http://dev.openlayers.org/releases/OpenLayers-2.10/examples/click-handler.ht
ml
                                               OpenLayers.Control.Click =
OpenLayers.Class(OpenLayers.Control, {
                defaultHandlerOptions: {
                    'single': true,
                    'double': false,
                    'pixelTolerance': 0,
                    'stopSingle': false,
                    'stopDouble': false
                initialize: function(options) {
                    this.handlerOptions = OpenLayers.Util.extend(
                        {}, this.defaultHandlerOptions
                    OpenLayers.Control.prototype.initialize.apply(
                        this, arguments
                    this.handler = new OpenLayers.Handler.Click(
                        this, {
                            'click': this.onClick
                        }, this.handlerOptions
                onClick: function(evt) {
                    var tempXY = explodeArray(evt.xy,',');
var aX = explodeArray(tempXY[0],'=');
var aY = explodeArray(tempXY[1],'=');
var tmpPixel = new OpenLayers.Pixel();
tmpPixel.x = aX[1];
tmpPixel.y = aY[1];
var aLonLat = map.getLonLatFromViewPortPx(tmpPixel);
doIdentify(aLonLat.lon,aLonLat.lat, aX[1], aY[1] );
//alert('X=' + aLonLat.lon + ' Y=' + aLonLat.lat);
                                               var controls;
                                               controls = {
                    "single": new OpenLayers.Control.Click({
                        handlerOptions: {
                            "single": true
                                               var props =
document.getElementById("props");
                                               // FIM:
ml
// INI - do identify...
                                                               var control;
                for(var key in controls) {
                    control = controls[key];
                    // only to route output here
                    control.key = key;
                    map.addControl(control);
                                               function toggle(key) {
                var control = controls[key];
                if(control.active) {
                    control.deactivate();
                } else {
                    control.activate();
                var status = document.getElementById(key + "Status");
                status.innerHTML = control.active ? "Navegar" : "Consultar";
What is the problem?
Thanks
Matheus Lacarini
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110609/783848fe/attachment-0001.html
