[mapserver-users] Fwd: Tile of tiles with tif images
Mark Korver
mwkorver at gmail.com
Thu Jun 9 11:09:46 EDT 2011
As Steve noted, if the input is TIF, then you prob want to be using
gdaltindex rather than tile4ms.
> Now we want to put them together (the Tiles),
> say, first, all the tiles from the images of the same province,
> and later, all the tiles from the provinces of the same projection.
when re-tile.py does it's work it knows nothing about what province
some TIF is in. For you to be able to calculate all the tiles that
are in the .dbf that are in some province, and I assume you are
talking about the shapefile index produced when using retile.py, you
would need to do a spatial query against that dbf using some political
boundary polygon.
Still, I am not sure what the goal here is. are you trying to re-tile
a set of TIFs to create a new group of tiles per province?
On Thu, Jun 9, 2011 at 9:47 AM, Juan Carlos Fuchs
<fuchs.juancarlos at gmail.com> wrote:
> Subject: Tile of tiles with tif images
> Dear Gentleman:
> Situation
> We have a collection of images tiled with re-tile.py.
> each record of our .dbf points to a diferent part of one tiff image.
> when we run tile4ms we get the following weird error
> Aborted. Unable to open
> DBF:/home/jfuch/public_html/wms/Fase8/cbers-2b-cordoba-laborde-168-b-137-4-02-may-09-img-img-tif
> If we get things right, each record in our tile file point to a different
> part of one tiff image, but the shp file has an geometric extend for each
> image
> so, why didn´t this work??
> Is there an other way to get an accelerated access to very huge tiffs file,
> sprengled over an big extension?
> Thanks in advance
> Cheers
> JC
> Juan Carlos Fuchs, arqto & mgtr.
> mapserver-users at lists.osgeo.org
