[mapserver-users] Re: WFS intersect request
John Callahan
john.callahan at udel.edu
Thu Jun 9 12:47:41 EDT 2011
Thanks. Yes, my server does support Intersect filter, according to the
WFS GetCaps file. I'm using the latest MS4W install with MS 6.
John
On Thursday, June 9, 2011, Alexandre Dube <adube at mapgears.com> wrote:
> Hello,
> If you run a WFS GetCapabilities request on your server, it should
> tell which filters it supports, see :
> http://mapserver.org/ogc/filter_encoding.html#server-side
> Someone correct me if I'm wrong, but I think MapServer needs to be
> compiled with GEOS in order to do intersect filters.
> HTH,
> Alexandre
> On 11-06-09 12:09 PM, John Callahan wrote:
> I have the following WFS intersect request that if
> working with GeoServer, and I'm trying to run this app with
> MapServer. The error I'm getting is:
> <ows:ExceptionText>msWFSGetFeature(): WFS server error.
> Invalid or Unsupported FILTER in GetFeature ...
> I've dome some reading but not sure exactly what's supported. I
> have used both INTERSECT and INTERSECTS, both return the same
> error. Should I skip these and go with BBOX? If so, I assume I
> would need to get rid of the lowerCorner/upperCorner items and
> just list the coordinates separated by commas. Or could there be
> a problem with the PropertyName = SHAPE? I couldn't find doc on
> what this value should be. My data are either shapefiles or
> postgis layers.
> The POST request is:
> <wfs:GetFeature resultType="hits" xmlns:wfs="http://www.opengis.net/wfs"
> service="WFS" version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <wfs:Query typeName="Municipal_Boundaries" srsName="EPSG:26957"
> xmlns:massgis="http://massgis.state.ma.us/featuretype">
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:Intersects>
> <ogc:PropertyName>SHAPE</ogc:PropertyName>
> <gml:Envelope xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:26957">
> <gml:lowerCorner>149081.76574899518
> 163078.62572595105</gml:lowerCorner>
> <gml:upperCorner>205627.85303800018
> 194899.95291598293</gml:upperCorner>
> </gml:Envelope>
> </ogc:Intersects>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> Thanks for any help you can provide.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey
> University of Delaware
> URL: http://www.dgs.udel.edu
> mapserver-users at lists.osgeo.org
> Alexandre Dubé
> Mapgears
> www.mapgears.com
