[mapserver-users] Unable to render a raster with 4 bands
jt2000 thakkar at nexgenwireless.com
Fri Jun 10 21:24:08 EDT 2011
I have a GRD raster that I'm trying to show on the map using mapserver.
Currently I'm getting all transparent output.
I've converted it to TIF using gdal_translate and it converted fine.  I also
used shp2img to convert to png without any issues.
Here is gdalinfo on the TIF file.
Driver: GTiff/GeoTIFF
Files: Test.tif
Size is 1293, 1276
Coordinate System is:
PROJCS["NAD83 / UTM zone 18N",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-75],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26918"]]
Origin = (306885.000000000000000,4328685.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  306885.000, 4328685.000) ( 77d13'57.95"W, 39d 5' 9.33"N)
Lower Left  (  306885.000, 4290405.000) ( 77d13'19.14"W, 38d44'28.42"N)
Upper Right (  345675.000, 4328685.000) ( 76d47' 4.23"W, 39d 5'37.14"N)
Lower Right (  345675.000, 4290405.000) ( 76d46'33.21"W, 38d44'55.89"N)
Center      (  326280.000, 4309545.000) ( 77d 0'13.63"W, 38d55' 3.48"N)
Band 1 Block=1293x1 Type=Byte, ColorInterp=Red
  NoData Value=0
Band 2 Block=1293x1 Type=Byte, ColorInterp=Green
  NoData Value=0
Band 3 Block=1293x1 Type=Byte, ColorInterp=Blue
  NoData Value=0
Band 4 Block=1293x1 Type=Byte, ColorInterp=Alpha
  NoData Value=0
  Offset: -200,   Scale:0.00305185094759972
I'm seeing this in the mapserver log.
[Fri Jun 10 19:57:28 2011].556592 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
file or PROCESSING directive ignored.  Not yet supported for
unclassified scaled data.
[Fri Jun 10 19:57:28 2011].569044 msPostGISLayerIsOpen called.
[Fri Jun 10 19:57:28 2011].891159 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:28 2011].891559 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:28 2011].891901 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:28 2011].892286 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:28 2011].903631 msPostGISLayerIsOpen called.
[Fri Jun 10 19:57:29 2011].131158 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:29 2011].131362 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:29 2011].131523 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
[Fri Jun 10 19:57:29 2011].131717 LoadGDALImage(rasterlayer): NODATA value 0
in GDAL
What do I need to change in the map file to make this work?
I have tried PROCESSING "SCALE=0,0.00305185094759972" to see if that would
help.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-render-a-raster-with-4-bands-tp6464301p6464301.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
