[mapserver-users] Requested BBOX outside requested coverage
Virginia Maffei
vmaffei at gmail.com
Tue Jun 14 10:15:09 EDT 2011
Thanks Stephen!
That was the problem!
Virginia
On Tue, Jun 14, 2011 at 10:34 AM, Stephan Meißl <stephan at meissl.name> wrote:
> Virginia,
> it looks strange that the second parameter in your bounding box is
> bigger than the fourth one.
> Besides that I suspect that you might be using different projections
> with different units (meter vs. degree).
> cu
> Stephan
> On Sat, 2011-06-11 at 18:46 -0300, Virginia Maffei wrote:
> > Hi, i want to do a getcoverage with wcs but the log throws:
> > [Sat Jun 11 18:27:50 2011].26000 msWCSGetCoverage(): WCS server error.
> > Requested BBOX
> > (-66.5079075029609,-84.6440997947261,-30.3257514953085,-83.1977984037033)
> is outside requested coverage BBOX
> (366582.290141166,6127927.10038269,857582.290141166,6670927.10038269)
> > [Sat Jun 11 18:27:50 2011].26000 freeLayer(): freeing layer at
> > 021CB940.
> > the url is:
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-1.map&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&coverage=localidades&CRS=EPSG:32721&BBOX=400000,700000,800000,600000&WIDTH=491&HEIGHT=543&FORMAT=GTiff
> > Could someone explain me whats wrong and how does bbox works?
> > Sorry, but i'm very new at this...
> > thank you!
> > Virginia
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110614/512ce7c7/attachment.html
