[mapserver-users] Question about MapServer
Jorge Arévalo
jorge.arevalo at deimos-space.com
Tue Jun 14 13:10:27 EDT 2011
Hello,
I'm executing Mapserver 5.6.4 under Apache2 in a Ubuntu 10.04 machine.
I'm having problems with a SLD file. Basically, when I execute a
request like this:
http://myserver/cgi-bin/mapserv?map=/var/mapserver/mapfiles/sld_cookbook_polygon.map&service=WMS&version=1.1.1&request=GetMap&layers=sld_cookbook_polygon&sld=http://myserver/sld/polygon_simplepolygon.sld
I get this error:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msSLDApplySLDURL: WMS server error. Could not open SLD
http://myserver/sld/polygon_simplepolygon.sld and save it in temporary
file /var/mapserver/output/4df778fc_14b7_0.sld.xml. Please make sure
that the sld url is valid and that imagepath and imageurl are set
properly in the map file
msHTTPExecuteRequests(): HTTP request error. HTTP: request failed with
curl error code 7 (Failed connect to agropilot:80; Operation now in
progress) for http://myserver/sld/polygon_simplepolygon.sld
</ServiceException>
</ServiceExceptionReport>
The log file shows this:
[Tue Jun 14 16:17:38 2011].364355 CGI Request 1 on process 4465
[Tue Jun 14 16:17:38 2011].410841 msHTTPExecuteRequests(): HTTP
request error. HTTP: request failed with curl error code 3 (<url>
malformed) for /var/mapserver/sld/polygon_simplepolygon.sld
[Tue Jun 14 16:17:38 2011].410930 msSLDApplySLDURL: WMS server error.
Could not open SLD /var/mapserver/sld/polygon_simplepolygon.sld and
save it in temporary file
/var/mapserver/output/4df76d82_1171_0.sld.xml. Please make sure that
the sld url is valid and that imagepath and imageurl are set properly
in the map file
[Tue Jun 14 16:17:38 2011].415803 mapserv request processing time
(msLoadMap not incl.): 0.051s
[Tue Jun 14 16:17:38 2011].415854 msFreeMap(): freeing map at 0x1168370.
[Tue Jun 14 17:06:36 2011].91881 CGI Request 1 on process 5303
[Tue Jun 14 17:06:39 2011].97592 msHTTPExecuteRequests(): HTTP request
error. HTTP: request failed with curl error code 7 (Failed connect to
agropilot:80; Operation now in progress) for
[Tue Jun 14 17:06:39 2011].97700 msSLDApplySLDURL: WMS server error.
Could not open SLD http://myserver/sld/polygon_simplepolygon.sld and
/var/mapserver/output/4df778fc_14b7_0.sld.xml. Please make sure that
in the map file
[Tue Jun 14 17:06:39 2011].97779 mapserv request processing time
(msLoadMap not incl.): 3.006s
[Tue Jun 14 17:06:39 2011].97799 msFreeMap(): freeing map at 0x18e4420.
The IMAGEPATH and IMAGEURL vars have a valid value in mapfile:
IMAGEPATH "/var/mapserver/output"
IMAGEURL "http://myserver/output"
The output directory exists and is writable by www-data (even when I
change permission to 777, the same error); http://myserver/output is
reachable. The curious thing is the file
/var/mapserver/output/4df778fc_14b7_0.sld.xml is actually created, but
it's empty.
I had problems before because apparmor didn't allow writing in
/var/www, but I changed the apache directory to /var/mapserver, and
now apache can write on it. In fac, it's writting a log file. I don't
understand this error. Any idea?
Many thanks in advance, and best regards,
Jorge Arévalo
Internet & Mobility Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
