[mapserver-users] Re: WFS intersect request
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Jun 16 08:18:21 EDT 2011
Hi John,
  Can you try something like :
<Filter><Intersects><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>-61.63,45.04
-60.78,45.04 -60.78,46.08
-61.63,46.08</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></Filter>,
Polygon, MultiPolygon, MultiSurface, Box, LineString are supported as
geometries for these operators.
gml:Envelope is not  right now.
Let me know.
best regards,
\On 09/06/2011 12:47 PM, John Callahan wrote:
> Thanks. Yes, my server does support Intersect filter, according to the
> WFS GetCaps file. I'm using the latest MS4W install with MS 6.
> John
> On Thursday, June 9, 2011, Alexandre Dube<adube at mapgears.com>  wrote:
>>      Hello,
>>        If you run a WFS GetCapabilities request on your server, it should
>>      tell which filters it supports, see :
>>      http://mapserver.org/ogc/filter_encoding.html#server-side
>>        Someone correct me if I'm wrong, but I think MapServer needs to be
>>      compiled with GEOS in order to do intersect filters.
>>      HTH,
>>      Alexandre
>>      On 11-06-09 12:09 PM, John Callahan wrote:
>>      I have the following WFS intersect request that if
>>        working with GeoServer, and I'm trying to run this app with
>>        MapServer.  The error I'm getting is:
>>        <ows:ExceptionText>msWFSGetFeature(): WFS server error.
>>        Invalid or Unsupported FILTER in GetFeature ...
>>        I've dome some reading but not sure exactly what's supported.  I
>>        have used both INTERSECT and INTERSECTS, both return the same
>>        error.  Should I skip these and go with BBOX?  If so, I assume I
>>        would need to get rid of the lowerCorner/upperCorner items and
>>        just list the coordinates separated by commas.  Or could there be
>>        a problem with the PropertyName = SHAPE?   I couldn't find doc on
>>        what this value should be.  My data are either shapefiles or
>>        postgis layers.
>>        The POST request is:
>>        <wfs:GetFeature resultType="hits" xmlns:wfs="http://www.opengis.net/wfs"
>>        service="WFS" version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
>>        http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
>>        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>>        <wfs:Query typeName="Municipal_Boundaries" srsName="EPSG:26957"
>>        xmlns:massgis="http://massgis.state.ma.us/featuretype">
>>        <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>        <ogc:Intersects>
>>        <ogc:PropertyName>SHAPE</ogc:PropertyName>
>>        <gml:Envelope xmlns:gml="http://www.opengis.net/gml"
>>        srsName="EPSG:26957">
>>        <gml:lowerCorner>149081.76574899518
>>        163078.62572595105</gml:lowerCorner>
>>        <gml:upperCorner>205627.85303800018
>>        194899.95291598293</gml:upperCorner>
>>        </gml:Envelope>
>>        </ogc:Intersects>
>>        </ogc:Filter>
>>        </wfs:Query>
>>        </wfs:GetFeature>
>>        Thanks for any help you can provide.
>>        - John
>>        John Callahan, Research Scientist
>>        Delaware Geological Survey
>>        University of Delaware
>>        URL: http://www.dgs.udel.edu
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
