[mapserver-users] Scalebar Object in PHP Mapscript
Steve.Toutant at inspq.qc.ca
Fri Jun 17 12:18:53 EDT 2011
Yes the units are set.
What do you mean by ?the map is well scaled but the scalebar is not ??
I mean the image printed is the same size as the map in my application.
But it seems that the scalebar is not appropriate
$oMap->setProjection is set to 900913 in php mapscript,
The WMS called is in Projection EPSG:32198, but 900913 is in the list of
available projections
Is it possible that php mapscript returns the map image in 900913, but a
scalebar in 32198?
Any other ideas
Thank you for your help,
Steve
"Lime, Steve D (DNR)" <steve.lime at state.mn.us>
2011-06-16 18:31
A
"Steve.Toutant at inspq.qc.ca" <Steve.Toutant at inspq.qc.ca>,
"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
cc
Objet
RE: [mapserver-users] Scalebar Object in PHP Mapscript
Other common params would be SIZE, STYLE and INTERVALS. Does the map have
units set?
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Thursday, June 16, 2011 12:29 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Scalebar Object in PHP Mapscript
I create a scalebar like this
$oMap->scalebar->set("units", MS_METERS);
$oMap->scalebar->outlinecolor->setRGB(0,0,0);
$oMap->scalebar->set("status", MS_EMBED);
And create an image of the map with the scalebar embedded
On the image, the map is well scaled but the scalebar is not.
Is the code above good? Is there some more parameters I should set?
thanks
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110617/9465ef2b/attachment.html
