[mapserver-users] Asking for guidelines about a project
Ben Madin
lists at remoteinformation.com.au
Tue Jun 21 00:29:46 EDT 2011
Brent et al,
Becoming off topic, but ours went something like :
DATA "the_move FROM (select ST_MakeLine(the_geom) as the_move, sq.polltime
FROM (SELECT the_geom, CAST(polltime AS date) as polltime
FROM vms
WHERE vesselname like '%pg_sql%'
ORDER BY polltime LIMIT 36) sq
GROUP BY sq.polltime) AS foo USING UNIQUE polltime USING SRID=4326"
but all credit for the concept goes to Regina Obe - I think she was showing running tracks! try postgresonline or the postgis list.
cheers
Ben
On 21/06/2011, at 11:15 AM, mapserver-users-request at lists.osgeo.org wrote:
> From: Brent Fraser <bfraser at geoanalytic.com>
> Date: 20 June 2011 11:43:52 PM AEST
> To: Ben Madin <lists at remoteinformation.com.au>
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Asking for guidelines about a project
> Ben,
> Our setup was similar. We had a current_location table and a archive_location table. To filter the archive_location for positions in the last 24 hours we had a view:
> CREATE VIEW archive_v AS
> SELECT
> archive_location.vessel_id,
> archive_location.time_fix,
> archive_location.speed,
> archive_location.heading,
> archive_location.vessel_coordinate,
> archive_location.archive_sequence,
> vessel_cfg.vessel_name,
> owner.org_name
> FROM archive_location,owner,vessel_cfg
> WHERE archive_location.owner_id=owner.org_id AND
> archive_location.vessel_id=vessel_cfg.vessel_id AND
> ((now() AT TIME ZONE 'utc') - (archive_location.time_fix)) <= '24 hour';
> I can't recall how we created linestrings for the tracks from the above view, but I think we used the archive_sequence number (this was assigned at insert time, per vessel) to order the points into lines.
> Best Regards,
> Brent Fraser
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110621/ee9374af/attachment.html
