[mapserver-users] Mapserver 6.0 regex
Chris Green
chris.green at ibstv.co.uk
Tue Jun 21 12:46:39 EDT 2011
Hi Steve
That's a very constructive suggestion. With no mapscript involved and with
the mapfile set up without a cluster class I added into the layer section:
FILTERITEM 'Groups'
FILTER /group4/
This worked: I got only group4 features.
Then I changed the mapfile to use a cluster class, with no filter: this
worked, I got all features clustered and with labels showing the
FeatureCount for each cluster.
Then I inserted the same FILTERITEM and FILTER into the layer as above, and
there is no output. Nada.
So it seems to be not a mapscript problem, but some kind of conflict between
clustering and filtering in Mapserver?
Chris
From: Lime, Steve D (DNR) [mailto:steve.lime at state.mn.us]
Sent: 21 June 2011 17:09
To: Chris Green; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Mapserver 6.0 regex
Hmmm. A plain 'ol regex expression did not change between 5.6 and 6.0, so
this is still valid:
FILTERITEM 'myitem'
FILTER /myregex/
Where regex's changed is inside logical expressions:
FILTER ('[myitem]' ~= /myregex/) becomes FILTER ('[myitem]' ~ 'myregex')
There are regression tests for these cases (query/filters.map) so I'm pretty
sure MapServer proper is working ok. You might try setting the filter and
filteritem directly in the mapfile see if that works. If it does then it's
likely a problem with PHP/MapScript.
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Chris Green
Sent: Monday, June 20, 2011 12:39 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Mapserver 6.0 regex
I have one (hopefully the last!) problem with migrating from Mapserver 4.6
to 6.0, this time over the use of regex.
Using Mapscript on a Fedora platform I have been setting a filter in this
manner:
$map=newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");
$layer1=$map->getLayerByName("test1");
$layer1->set("filteritem", "Attribute1");
$layer1->setFilter("/target/");
This worked fine, but not anymore. I see in the migration guide that a
regex should now be delineated as a string so I assume that "/target/"
should become "target". But that doesn't work either.
I am wondering if part of the problem is that as well as going from
Mapserver 4.6 to 5.0 I also changed from Fedora to Ubuntu 10.04, and I see
from the Mapserver documentation on Expressions that the OS may affect regex
operation.
Am I missing something obvious here? I am really tired of going in circles
over this.
Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110621/329c6754/attachment.html
