[mapserver-users] symbol position moving when using angle
thomas bonfort thomas.bonfort at gmail.com
Tue Jun 21 14:11:18 EDT 2011
6.0 should be ok except for GD: have a look in
msautotest/renderers/point-truetype. I would guess a recent 5.x is ok with
agg to. Guetting it to work with GD is very low on my todo  list (i.e.
improbable without funding)
Le 21 juin 2011 20:02, "Bart van den Eijnden" <bartvde at osgis.nl> a écrit :
> Hi Thomas,
> I tested both 5.2 and 5.7 (i.e. trunk a few months after the 5.6 release).
> Renderer: my guess is GD but I would need to check on Thursday to be sure.
> Best regards,
> Bart
> Sent from my iPhone
> On Jun 21, 2011, at 7:52 PM, thomas bonfort <thomas.bonfort at gmail.com>
wrote:
>> Bart,
>> What mapserver version, and which renderer?
>> Le 21 juin 2011 14:38, "Bart van den Eijnden (OSGIS)" <bartvde at osgis.nl>
a écrit :
>> > Hi list,
>> > hopefully someone can explain the following issue to me.
>> > I am using a vector symbol (ttf), and when using no angle, it is
>> > positioned correctly.
>> > However, when I use ANGLE on the STYLE (using an attribute in the
>> > dataset), things get weird and the symbol position changes.
>> > Image brous4.png (no rotation in Mapserver, red exclamation marks are
>> > Mapserver, black exclamation marks are ArcMap, blue dot is the same
>> > Mapserver layer using a circle symbol to display the location):
>> > http://www.osgis.nl/download/mapserver/brous4.png
>> > Image brous3.png, now we rotate the symbols in Mapserver, but their
>> > location is moving (a simple OFFSET does not seem to be a possible
>> > solution however):
>> > http://www.osgis.nl/download/mapserver/brous3.png
>> > TIA for any guidance.
>> > Best regards,
>> > Bart
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110621/b92f06da/attachment-0001.html
