[mapserver-users] MySQL connection: so near, yet so far...
Chris Green
chris.green at ibstv.co.uk
Wed Jun 22 07:17:35 EDT 2011
I am trying to establish a MySQL connection to a Mapserver 6.0 layer using
OGR. After much trial and error (mostly error) I have got to the point where
I have an ovf file which I can test using ogrinfo, but which I cannot make
work in a layer.
My ovf file (OGR_test.ovf) is
<OGRVRTDataSource>
<OGRVRTLayer name="OGR_test">
<SrcDataSource>mysql:testDB,user=root,password=mysql,port=3306,tables=testTa
ble</SrcDataSource>
<SrcSQL>SELECT City, Latitude, Longitude FROM testTable</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="Longitude"
y="Latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
I can successfully test this and see the data in testTable via:
~# ogrinfo var/www/vhosts/mysite/httpdocs/data/OGR_test.ovf
However when I create a test layer I cannot establish the OGR connection. I
am trying with:
LAYER
NAME "testLayer"
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "OGR_test.ovf"
DATA "OGR_test"
CLASS
NAME "MyClass"
STYLE
SYMBOL 'circle'
SIZE 15
COLOR 0 255 0
END
END
END
This produces an "internal server error".
I have also tried using an absolute path to OGR_test.ovf, still no success.
It seems that I have not got the CONNECTION and DATA parameters right but
after reading the MySQL and the OGR sections in the Mapserver documentation
many times I still can't figure out what I'm doing wrong.
Can someone help?
Regards,
Chris
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Chris Green
Sent: 22 June 2011 10:09
To: 'Rahkonen Jukka'; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Mapserver layer - MySQL connection
Jukka
It seems I celebrated too soon.....although this now succeeds:
~# ogrinfo mysql:testDB,user=root,password=mysql,port=3306
...when I try to create an ovf file like so:
<OGRVRTDataSource>
<OGRVRTLayer name="testLayer">
ble</SrcDataSource>
y="Latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
I get the error "Unable to open datasource
'var/www/vhosts/mysite/httpdocs/OGR_test.ovf' with the following drivers."
This is followed by the list of drivers which includes MySQL.
Something wrong in my ovf file?
Chris
Sent: 22 June 2011 08:29
Jukka
You are a genius -it worked!
Thanks
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: 22 June 2011 08:26
To: Chris Green; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver layer - MySQL connection
Try first by removing the space characters after separating commas.
-Jukka Rahkonen-
________________________________________
Lähettäjä: mapserver-users-bounces at lists.osgeo.org
[mapserver-users-bounces at lists.osgeo.org] käyttäjän Chris
Green [chris.green at ibstv.co.uk] puolesta
Lähetetty: 22. kesäkuuta 2011 10:12
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Mapserver layer - MySQL connection
Hi all
Im using Mapserver 6.0 and I have GDAL 1.8.0 installed, running under
Ubuntu 10.04. I am trying to make a connection from a layer to MySQL,
following the guidance given in the MySQL section of Mapserver
documentation. My problem is that when I try to connect using ogrinfo like:
~# ogrinfo mysql:testDB, user=root, password=mysql, port=3306
I get a mySQL connect failure message ERROR 1: MySQL connect failed for:
testDB, Access denied for userroot@localhost (using password: NO)
It seems that MySQL is refusing this connection request because the password
that I entered in the ogrinfo command is not being passed to MySQL and I
cant find a way to overcome this. The same user name and password work fine
if I access MySQL directly rather than via ogrinfo.
Does anyone have an idea what my problem is?
Chris
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
