[mapserver-users] MySQL connection: so near, yet so far...
Fawcett, David (MPCA)
david.fawcett at state.mn.us
Wed Jun 22 10:38:35 EDT 2011
You should be able to add a projection block to your layer, specifying that your layer data is geographic (probably epsg:4326?)
Then add a projection block to the MAP block of your map file to specify that the output projection for your map is epsg:900913. If 900913 isn't in your proj4 database, you could try epsg:3785.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Chris Green
Sent: Wednesday, June 22, 2011 9:17 AM
To: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] MySQL connection: so near, yet so far...
Thanks Stephen
That was a useful pointer, I have the OGR connection working now. One
remaining problem: the source data in my MySQL database is unprojected
lat/lon, and I want to project to Google 900913.
It seems that it should be possible to get OGR to do this within the ovf
file by including an SRS statement like <LayerSRS>EPSG:900913</LayerSRS>,
but this doesn't work. Adding a projection statement to the layer doesn't
help either.
Anyone know how to do this?
Chris
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephan Holl
Sent: 22 June 2011 12:56
Subject: Re: [mapserver-users] MySQL connection: so near, yet so far...
Hello Chris,
"Chris Green" <chris.green at ibstv.co.uk>, [20110622 - 12:17:35]
> I am trying to establish a MySQL connection to a Mapserver 6.0 layer
> using OGR. After much trial and error (mostly error) I have got to the
> point where I have an ovf file which I can test using ogrinfo, but
> which I cannot make work in a layer.
> My ovf file (OGR_test.ovf) is
> <OGRVRTDataSource>
> <OGRVRTLayer name="OGR_test">
> <SrcDataSource>mysql:testDB,user=root,password=mysql,port=3306,tables=
> testTa
> ble</SrcDataSource>
> <SrcSQL>SELECT City, Latitude, Longitude FROM
> testTable</SrcSQL> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="Longitude"
> y="Latitude"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> I can successfully test this and see the data in testTable via:
> ~# ogrinfo var/www/vhosts/mysite/httpdocs/data/OGR_test.ovf
> However when I create a test layer I cannot establish the OGR
> connection. I am trying with:
> LAYER
> NAME "testLayer"
> STATUS DEFAULT
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "OGR_test.ovf"
> DATA "OGR_test"
> CLASS
> NAME "MyClass"
> STYLE
> SYMBOL 'circle'
> SIZE 15
> COLOR 0 255 0
> END
> END
> END
> This produces an "internal server error".
> I have also tried using an absolute path to OGR_test.ovf, still no
> success. It seems that I have not got the CONNECTION and DATA
> parameters right but after reading the MySQL and the OGR sections in
> the Mapserver documentation many times I still can't figure out what
> I'm doing wrong.
> Can someone help?
Just a guess.
Make sure you have the exact same env-vars set for apache as you have set
within the shell your ogrinfo-command works. Sometimes there can be a
differnces there?
Best
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
