AW: [mapserver-users] "Low-resolution" raster image problem when
usingOpenlayers
kensei3000
kensei3000 at yahoo.com
Wed Jun 29 22:57:49 EDT 2011
Hi Arnd,
I see. I used the same 'mapserv' url in both OpenLayers.Layer.WMS and .MapServer code. The requests were sent to the same remote server. So the difference must be in the requests. Is it possible that OpenLayers.Layer.WMS generated a different output url string from the one generated by OpenLayers.Layer.MapServer?
Ken
To: 'kensei3000' <kensei3000 at yahoo.com>
Cc: mapserver-users at lists.osgeo.org
Sent: Thursday, June 30, 2011 1:15 AM
Subject: AW: [mapserver-users] "Low-resolution" raster image problem when usingOpenlayers
Hi Ken,
Quote : "Interestingly, if I use the 'mapserv'
executable directly in the browser instead of using OpenLayers API, the image
also renders correctly."
There could be no difference
(OpenLayers.Layer.WMS or .MapServer), because with OpenLayers you only create an
url for an image tag (<img src="url">). The response have to be the same
as from the browser directly.
The difference could only be a result
from different requests or the same request to different
servers.
Arnd
Von: kensei3000
[mailto:kensei3000 at yahoo.com]
Gesendet: Mittwoch, 29. Juni 2011
09:56
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: AW: [mapserver-users]
usingOpenlayers
Hi
Arnd,
I
checked the images properties of the tile images using ImageMagick.
has image type "Palette" (8-bit)
has image type "TrueColor" (32-bit)
The
results I got seem to correlate with your findings.
Indeed,
it appears that the image rendering between my local pc and the server are
different.
The map
files are exactly same since I sync them in both computers.
The
MapServer versions, however, are different. Here's what I got:
LOCAL:
MapServer version 6.0.0 OUTPUT=GIF
OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
REMOTE:
MapServer version 5.6.1 OUTPUT=GIF
OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7
The MapServer executable in the remote
server is an older version (5.6.1) than the one in my pc (6.0.0). I edited the
map files and images in my local pc, then synced them to the server, so there
may be an incompatibility. I checked the Mapserver Migration Guide
(http://mapserver.org/de/MIGRATION_GUIDE.html) and my guess was that the default
OUTPUTFORMAT specifications of both versions could be
different. I
did not specify an explicit OUTPUTFORMAT in my map file.
I created another test. This time I
explicitly defined the OUTPUTFORMAT with the following lines added to the map
file in the remote server:
OUTPUTFORMAT
NAME jpeg
DRIVER "AGG/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
The
result was that the output image generated by the remote server rendered in
TrueColor, similar to the output image in my local pc. Problem appears to be
fixed.
My guess right now is
that the IMAGEMODE parameter above was somehow set to PC256 (i.e. 8-bit
color palette) by default.
Interestingly, if I
use the 'mapserv' executable directly in the browser instead of using OpenLayers
API, the image also renders correctly.
EXAMPLE:
http://remotehost/cgi-bin/mapserv?map=/opt/maps/sandbox/mapserver_openlayers_if/sample.map&mode=map
Above 'sample.map' did not have the
OUTPUTFORMAT object explicitly defined.
In another test I ran using the
original 'sample.map' (i.e. no OUTPUTFORMAT object), I edited the OpenLayers
code in the remote server:
//sample.html
17
layer = new OpenLayers.Layer.MapServer("World
Map",
TO:
17 layer = new
OpenLayers.Layer.WMS("World Map",
I used the generic 'WMS' layer instead
of the 'MapServer' layer. And the result was that the output image rendered
correctly. I am not yet sure why.
I might need to run
additional tests to confirm my findings.
Thanks for your help
in pointing out the discrepancies in the images and in MapServer.
Ken
<arnd.wippermann at web.de>
To: 'kensei3000'
Sent: Wednesday, June 29, 2011 2:28
AM
Subject: AW:
usingOpenlayers
use some image viewer to get information
of your images.
tile_topleft_remote.pngis a 8bit image (256 color image), where
only 45 colors used.
tile_topleft_local.png is a 24bit image
(16,7 Mill. colors), where 13274 colors used.
The requests ask for map_imagetype=png. So
it seems, that your mapfiles are different, because the response of the servers
delivers a different image for the same imagetype. Or do you
use different MapServer versions?
The problem has to be an issue with
MapServer and not with OpenLayers.
Arnd
Von: kensei3000
Gesendet: Dienstag, 28. Juni 2011
04:32
An: Arnd Wippermann
Hi
Arnd,
Thanks
a lot for the tip. I copied the image url of the top-left most tile for both
local pc and remote server tests.
Here is
what I got:
Local:
http://localhost/cgi-bin/mapserv?map=%2Fopt%2Fmaps%2Fsandbox%2Fmapserver_openlayers_if%2Fsample.map&layers=sample_raster&mode=map&map_imagetype=png&mapext=-90+0+0+90&imgext=-90+0+0+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
Remote:
http://remotehost/cgi-bin/mapserv?map=%2Fopt%2Fmaps%2Fsandbox%2Fmapserver_openlayers_if%2Fsample.map&layers=sample_raster&mode=map&map_imagetype=png&mapext=-180+-90+0+90&imgext=-180+-90+0+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
The only significant
difference of the two urls appear to be the 'mapext' and 'imgext' parameters.
When I checked the resulting images after inputting the urls in the browser, I
noticed that the tile images had different sizes and positions. I believe this
was due to the said parameters. I tried changing the 'mapext' and 'imagext'
parameters of the server test url to match that of the local test url, and
indeed the size and position of the remote server tile image changed. However, I
am still unable to figure out what causes the color distortion or "downsampling"
of the image in the remote server.
For further reference,
I've attached the tile images I got using the above urls.
Here is the openlayers
code I used. It is the same for both local and remote server tests except for
the host in line 18.
//sample.html
1<html
xmlns="http://www.w3.org/1999/xhtml">
2 <head>
3 <style
type="text/css">
4 #map
5
width: 1024px;
6
height: 768px;
7
border: 1px solid black;
8 }
9 </style>
10 <script
src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
11 <script
type="text/javascript">
12
13 var map,
layer;
14
15 function
init(){
16
map = new OpenLayers.Map( 'map' );
17
layer = new OpenLayers.Layer.MapServer("World Map",
18
"http://localhost/cgi-bin/mapserv",
19
{map:
'/opt/maps/sandbox/mapserver_openlayers_if/sample.map', layers:
'sample_raster'});
20
map.addLayer(layer);
21
map.zoomToMaxExtent();
22 }
23 //
24 </script>
25 </head>
26 <body
onload="init()">
27 <div
id="map"></div>
28 </body>
29</html>
And below is the common
.map file I created with the help of the Quantum GIS Mapserver Export
tool.
The raster image has an
associated World file (.wld) for georeferencing.
1# Map file created from QGIS project
file /var/maps/sandbox/mapserver_openlayers_if/sample.qgs
2# Edit this file to customize for your
map interface
3# (Created with PyQgis MapServer
Export plugin)
4MAP
5 NAME "QGIS-MAP"
6 # Map image size
7 SIZE 8180 4930
8 UNITS meters
9
10 EXTENT -86.515507 -50.290979
88.076495 48.225271
11 PROJECTION
12 'proj=longlat'
13 'ellps=WGS84'
14
'towgs84=0,0,0,0,0,0,0'
15 'no_defs'
16 END
17
18 # Background color for the map
canvas -- change as desired
19 IMAGECOLOR 255 255 255
20 IMAGEQUALITY 95
21 IMAGETYPE jpeg
22
23 # Legend
24 LEGEND
25 IMAGECOLOR 255 255
255
26 STATUS ON
27 KEYSIZE 18 12
28 LABEL
29 TYPE BITMAP
30 SIZE MEDIUM
31 COLOR 0 0 89
32 END
33 END
34
35 # Web interface definition. Only
the template parameter
36 # is required to display a map.
See MapServer documentation
37 WEB
38 # Set IMAGEPATH to the
path where MapServer should
39 # write its output.
40 IMAGEPATH '/tmp/'
41
42 # Set IMAGEURL to the url
that points to IMAGEPATH
43 # as defined in your web
server configuration
44 IMAGEURL '/tmp/'
45
46 #Scale range at which web
interface will operate
47 # Template and
header/footer settings
48 # Only the template
parameter is required to display a map. See MapServer documentation
49 TEMPLATE
'fooOnlyForWMSGetFeatureInfo'
50 END
51
52 LAYER
53 NAME
'sample_raster'
54 TYPE RASTER
55 DUMP true
56 TEMPLATE
57 EXTENT -86.515507 -50.290979
88.076495 48.225271
58 DATA
'sec_field.jpg'
59 STATUS DEFAULT
60 TRANSPARENCY 100
61 PROJECTION
62 'proj=longlat'
63 'ellps=WGS84'
64
65 'no_defs'
66 END
67 END
68
69END
Hope you could provide
further assistance.
Ken
To: 'kensei3000'
Sent: Tuesday, June 28, 2011 1:53
AM
Subject: AW:
usingOpenlayers
hi,
if you do a right click on a tile to get the context menu, you
should be able to copy the url (if the tiles of your server is the most top of
the visible layers). Compare the different urls. If you load them in your
browser you should get a response for a single tile from your
server.
Perhaps that gives you an idea, what goes
wrong.
Arnd
Von: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von kensei3000
Gesendet: Montag, 27. Juni 2011 05:37
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users]
Hi!
I am trying to use MapServer as a WMS layer in Openlayers. I setup the
MapServer in our server machine, using my own PC as the test client. I created a
simple .map file in our server that contains one raster image. Using the
mapserver tool 'mapserv' in a URL string, I was able to load the output map with
full resolution correctly in a browser (Google Chrome). However, when I tried to
load the map using a simple Openlayers script (HMTL) which I created on our
server (accessible via browser), the map image appeared to have a much
lower-resolution (i.e. 256-colors only) and was pixelized. Also, I could see
white lines representing the tile edges of the map.
I did another test. This time, I installed MapServer in my own PC. I
created a .map file similar to the one I used in our server, with the same
raster image. I created a similar Openlayers script (HTML) in my own PC, but
this time it would call the MapServer from my own PC. I loaded the script using
a browser and the image displayed correctly with full resolution.
Does anyone have an idea what the problem could be?
I would appreciate any help in this matter.
Thanks in advance! :)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110629/3f5442ce/attachment-0001.html
