[mapserver-users] MapServer 6.0.0-beta1 release - Please test!
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Fri Mar 11 11:11:04 EST 2011
Hi Daniel
--------Daniel Morissette <dmorissette at mapgears.com> wrote--------
Subject: Re: [mapserver-users] MapServer 6.0.0-beta1 release - Please test!
Date: 10.03.2011 20:05
>Hi Peter,
>It is quite likely that you are using a SWIG version newer than 1.3.36.
CentOS comes with swig 1.3.29, which, I guess, is not recent enough. I tried to skip "make interface", but swig is run even without this. How can I avoid that swig regenerates the wrappers?
Anyway, having a closer look, it seems more that CCFLAGS was not build correctly, since it contains things like "@AGG_ENABLED@ @PDF_ENABLED@" which leads to the errors:
gcc: @AGG_ENABLED@: No such file or directory
gcc: @PDF_ENABLED@: No such file or directory
gcc: @PDF_INC@: No such file or directory
The others are just warnings.
>The Java SWIG wrappers work best with SWIG 1.3.36. The MapServer source
>package already contains SWIG wrappers generated using SWIG 1.3.36 so
>you could use that, or if you must regenerate them then I'd suggest that
>you try with SWIG 1.3.36.
>Daniel
Peter
R3 GIS Srl - GmbH
http://www.r3-gis.com
>On 11-03-10 02:02 PM, Peter Hopfgartner wrote:
>> While trying to build the package for CentOS 5.6, I stumble on Java
>support:
>> + cd ../java
>> + JAVA_HOME=/usr/lib/jvm/java-1.6.0
>> + make interface
>> mkdir -p edu/umn/gis/mapscript
>> swig -java -package edu.umn.gis.mapscript -outdir edu/umn/gis/mapscript
>-o mapscript_wrap.c ../mapscript.i
>> + make
>> javac edu/umn/gis/mapscript/*.java
>> gcc -fpic -c -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
>-fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC
>-Wall  -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR
>-DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_WFS_LYR
>-DUSE_WCS_SVR -DUSE_SOS_SVR   -DUSE_JPEG -DUSE_GD_GIF -DUSE_GD_PNG
>-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW
>-DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS
>-DGD_HAS_GET_TRUE_COLOR_PIXEL @AGG_ENABLED@ @PDF_ENABLED@  -DUSE_OGR
>-DUSE_GDAL -DUSE_GEOS -DUSE_ICONV -DUSE_POSTGIS
>-DPOSTGIS_HAS_SERVER_VERSION -DUSE_MYGIS -DUSE_THREAD -I/usr/include
>-Irenderers/agg/include  @PDF_INC@     -I/usr/include/php/ext/ereg/
>-I/usr/include/gdal -I/usr/include -I/usr/include/mysql  -g -pipe
>-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
>--param=ssp-buffer-size=4 -m64 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64
>-D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv    -I/usr/include
>-I/usr/include/libxml2 -I/usr/l
>ib/jvm/java-1.6.0/include -I/usr/lib/jvm/java-1.6.0/include/linux
>-fno-strict-aliasing mapscript_wrap.c
>> mapscript_wrap.c: In function 'new_imageObj':
>> mapscript_wrap.c:2746: warning: passing argument 1 of
>'renderer->loadImageFromFile' discards qualifiers from pointer target type
>'Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1getBytes':
>> mapscript_wrap.c:29157: warning: pointer targets in passing argument 2
>of 'SWIG_JavaArrayOutSchar' differ in signedness
>'Java_edu_umn_gis_mapscript_mapscriptJNI_msIO_1getStdoutBufferBytes':
>> mapscript_wrap.c:43772: warning: pointer targets in passing argument 2
>> make: *** [mapscript_so] Error 1
>> error: Bad exit status from /home/rpmbuild/rpmbuild/tmp/rpm-tmp.49448
>(%build)
>> RPM build errors:
>(%build)
>> [rpmbuild at rpm-devel ~]$
>> Regards,
>> Peter
>> R3 GIS Srl - GmbH
>> --------Daniel Morissette<dmorissette at mapgears.com>  wrote--------
>> Subject: [mapserver-users] MapServer 6.0.0-beta1 release - Please test!
>> Date: 10.03.2011 03:48
>>> The MapServer Team is pleased to announce the release of MapServer
>>> 6.0.0-beta1. This is the first beta on our way to a final 6.0 release.
>>> This new release introduces important changes in key components of the
>>> MapServer core (rendering, query and expressions), and for this reason
>>> we count on you, MapServer power users, to help test the release in
>your
>>> respective environments and provide feedback (through the users list
>or
>>> Trac tickets).
>>> Thanks! - The MapServer Team
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>Daniel Morissette
>http://www.mapgears.com/
>Provider of Professional MapServer Support since 2000
