[mapserver-users] two mapserver speed-optimization questions
Vince Miller
vincentpmiller at yahoo.com
Tue Mar 15 17:03:29 EDT 2011
I'm new to this list. A quick search did not find answers to two mapserver speed-optimization questions. Can someone please
help?
1. The following two lines of PHP from my application transform an php image object into a raster map layer:
imagepng($rmap, __MAPS_PATH__ . "resource.png");
$map->getLayerByName("resource")->set("data", __MAPS_PATH__ . "resource.png");
The imagepng call is a major bottleneck when the extent of the layer is large.
Can the data in
image "$rmap" be accessed for layer "resource" directly, without the file write/read? If so, how? FYI, the following lines appear in my mapfile:
LAYER
NAME resource
DATA "resource.png"
TYPE raster
PROCESSING "RESAMPLE=NEAREST"
END
2. When
large vector layers are included in the map, or when the layer consists of labels, the mapObj's draw method is slow, even if only a small portion of the layer data is needed.
Sample SQL that created the layer data column is:
CREATE TABLE domains (
domid integer PRIMARY KEY,
SELECT AddGeometryColumn('','domains','boundaries','4326','MULTIPOLYGON',2);
\i boundaries.sql; /* contains a bunch of INSERT INTOs */
CREATE INDEX dombound_idx ON domains USING gist (boundaries);
ALTER TABLE domains CLUSTER ON dombound_idx;
and the mapfile has:
LAYER
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
NAME boundaries
DATA "boundaries from domains using unique
domid"
TYPE POLYGON
CLASS
END
END
Any suggestions for speeding this up?
Thanks a bunch,
Vince
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110315/1ea29d0d/attachment.html
