[mapserver-users] MapServer 6.0.0-beta2 release: problems building Java MapScript
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Sat Mar 19 04:19:28 EDT 2011
On CentOS 5.5:
After running
./configure --with-gd --with-zlib --with-tiff --with-freetype --with-gdal --with-ogr --with-geos --with-proj --with-sos --with-wfs --with-wcs --with-wmsclient --with-wfsclient --with-xpm --with-agg --with-cairo --with-postgis --with-curl-config --with-xml2-config --with-threads --enable-debug
in mapscript/java/Makefile I've found the following, which causes some troubles afterwards:
AGG=     @AGG_ENABLED@
AGG_INC=  -Irenderers/agg/include
PDF_INC=  @PDF_INC@
PDF_LIB=  @PDF_LIB@
PDF=      @PDF_ENABLED@
I have the same situation with Ubuntu 10.04 on current SVN, as of now.
Unfortunatly my autoconf skills are very low, so I not really know how to provide a fix or better diagnosis.
Peter
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Daniel Morissette <dmorissette at mapgears.com> wrote--------
Subject: [mapserver-users] MapServer 6.0.0-beta2 release
Date: 18.03.2011 20:48
>Thanks to the hard work from everyone during the Montreal Code Sprint
>this week (http://wiki.osgeo.org/wiki/Montreal_Code_Sprint_2011), the
>MapServer Team is pleased to announce the release of MapServer
>6.0.0-beta2. This is the latest beta on our way to a final 6.0 release,
>and includes a large number of fixes made during the Montreal Code
>Sprint.
>The 6.0 release introduces important changes in key components of the
>MapServer core (rendering, query and expressions), and for this reason
>we count on you, MapServer power users, to help test the release in your
>respective environments and provide feedback (through the users list or
>Trac tickets).
>This is the second of four planned beta releases and if all goes well a
>final release should occur around the end of April. The full release
>plan which also includes the list of new features and changes in this
>release is available at:
>   http://mapserver.org/trunk/development/release/release-plan-6.0.html
>The list of fixes since beta1 is attached at the end of this message.
>For a complete list see the HISTORY.TXT file at:
>http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-beta2/mapserver/HISTORY.TXT
>We have started working on a 5.6 -> 6.0 migration guide. This document
>contains important notes on backwards incompatibilities or other changes
>required when upgrading to 6.0. It is not complete yet but we strongly
>recommend that you review the latest version online at:
>     http://mapserver.org/trunk/MIGRATION_GUIDE.html
>The source for this release can be downloaded at:
>     http://mapserver.org/download.html
>or
>     http://download.osgeo.org/mapserver/mapserver-6.0.0-beta2.tar.gz
>The binary distributions listed in the download page should be updated
>with binaries for the new beta release in the next day or so.
>Once again we need your help to ensure a high quality product, so please
>help out by testing your applications with this new code base.
>Thanks! - The MapServer Team
>Version 6.0.0-beta2 (2011-03-18)
>- correct scaling of symbol GAP and PATTERN (#3752)
>- remove references to SWF/MING
>- CGI runtime substitution requires a validation pattern (was optional
>   before) (#3522)
>- add a default png8 outputformat that uses AGG/PNG with quantization
>- change MS_INIT_COLOR to take alpha as a parameter
>- stop using style->opacity in rendering code, use alpha from colorObjs.
>- Fixed big Oracle memory leak when rendering in KML (#3719)
>- avoid linking in postgres dependencies unnecessarily (#3708)
>- don't initialize outputformats until they are selected
>- use "seamless" creation of tiles for polygon fills with vector symbols
>- Ability to escape single/double quotes inside a string (#3706)
>- Globally replace msCaseFindSubstring with strcasestr (#3255)
>- support GROUP layers in shp2img (#3746)
>- Honour MAXSIZE for WCS 2.0 responses (#3204).
>- fallback to ows_title for WCS ows:Title of CoverageDescription (#3528)
>- Added msIO_stripStdoutBufferContentHeaders() to strip off all
>   Content-* headers from a buffer (#3673, #3665).
>- Added raster classification support for STYLE level OPACITY.
>- Allow attribute references, that is [itemname], within a TEXT string
>(#3736)
>- Fixed segmentation fault when parsing invalid extent arguments in
>   shp2img (#3734)
>- Make "openlayers mode" work even without OWS support (#3732)
>- Add a static table to define the axis order for soem epsg codes (#3582)
>- Add possibility to use KML_NAME_ITEM (#3728)
>- Fixed mapfile parsing error when a label angle referenced an attribute
>   (e.g. ANGLE [angle]) #3727
>- Removed executable flag on some source files (#3726)
>- Fixed SQL Spatial to be able to use UniqueIdentifier field as unique
>   key (#3722)
>- Fix PHP Windows build (#3714)
>- Fixed --with-opengl build issue: Look for OpenGL libs under /usr/lib64
>as
>   well (#3724)
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
